Question about Motorola Mobility C261 Cellular Phone
Housing/faceplate How do I remove and install a new faceplate for this phone? Special tools needed?
    Problem Solver:
  • 9 Answers
I believe faceplates are not available for this phone. Check with the company on their website .
Posted on Jul 13, 2008
6ya staff
SOURCE:
Where is the water pump located?
Here is the complete procedure to replace the pump on your 99 Deville.
You will need to purchase the special water pump removal/installation tool.
1. Drain the cooling system.
2. Remove both radiator hoses
The water pump is on the right hand side of the engine and is driven by a pulley that comes off of one of the overhead cams.
3. remove the air cleaner assembly.
4. remove the pulley guard.
5. loosen the tensioner and take the belt off of the pulley.
If you decide to replace the belt you need to remove the tensioner, remove the studs that the pulley guard came off of and the tensioner will come out.
6. remove the water pump housing cover. the thermostat housing is bolted to this cover. it has (4)10mm bolts that hold it on.
7. using the special tool, turn the water pump clockwise (it twist-locks into the housing) and remove it.
8. clean all sufaces, replace both o-rings.
9. CAREFULLY! install the new pump with the special tool. be careful that you turn it all the way in counter-clockwise but that you don't pull too hard. The pump has steel tabs that lock into grooves in an aluminum housing. if you damage that housing by forcing the pump too hard you will cost yourself a ton of time and money.
10. re-assemble the engine in reverse order as disassembly.
don't forget to use your torque specs. You are working with aluminum castings
Aug 26, 2011 | 1999 Cadillac DeVille
Tip
How do I replace the water pump on my Cadillac Deville?
Hi.
Here the instructions.
  • Take off the plastic cover located near the top of the radiator if present.
  • Remove the protective shield located on top of the belt pulling the water pump. You will need to undo two 10mm nuts and one 10mm bolt.
  • Undo the 10mm nut that holds water pump housing togeter with the oil dipstick.
  • Take off the air intake assembly.
  • Move the PCM computer to one side, ensure that the module is safely placed.
  • Release the belt tensioner using a big flat screwdriver.
  • Remove the serpentine belt from the water pump pulley
  • Remove the upper radiator hose. This is held by a metal clamp. Use plyers to remove the clamp.
  • Remove also the clamp from the thermostat housing bypass hose, without removing the hose (you have to bleed coolant first).
  • Unscrew the four 10mm bolts that hold the water pump housing and letcoolant drain from water pump plug. At this point you can also removethe lower radiator hose to drain faster.
  • After coolant drains remove the water pump housing.
  • At this point you have to use a special Water Pump removal tool onwater pump cand turn clockwise until the pump is sliding off thehousing.
  • Remove the pump and the o-ring located inside the water pump housing.
  • Clean and grease the area, put a new o-ring and install back water pump housing
  • Install the new water pump using the special tool and following operations in reverse order.
You may need to use sealant tabs from a Cadillac or GM dealer. Here is what you need.
Better going to your local dealer to get the best product for yourCadillac. You will also need a 3/8'' ratchet, socket and extensions
Youmay also need to replace the housing cover gasket. You will need toreplace the O-Ring, that usually comes with the new pump.
When installing new pump you must also ensure that the new pump is aligned correctly,one of the tabs on the pump housing is different and will lock up the pump, so it must bealigned properly while installing.
Here pump:2000 Cadillac DeVille Water Pump
Here the special tool: Water Pump Removal and Installation Impact Socket
on Mar 16, 2010 | 2000 Cadillac DeVille
My cadillac eldorado etc 98 model needs a water pump pulley i can not find it anywhere does it go by any other name it is over heating and a we called a mech friend and he said it was the water pump and...
The water pump should come with a pulley on it or at least transfer over to the new one if it doesn't come with a pulley. Water Pump Removal and Installation All Engines To Remove:
  1. Before servicing the vehicle, refer to the Cautions and Warnings in the beginning of this section.
  2. Remove or disconnect the following:
    • Coolant into a suitable container
    • Upper filler panel
    • Air cleaner assembly
    • Secondary AIR injection control valve gm_car_cad_sev_wtr_pmp_belt_shld.gif
    • Oil level indicator tube nut
    • Water pump belt shield fasteners
    • Radiator outlet hose from the thermostat housing gm_car_cad_sev_wtr_pmp_and_covr.gif
    • Water pump cover bolts
    • Water pump cover
    • Heater return hose
  3. Position suitable water pump puller/installer tool (or special service tool J38816-A) to the water pump locking ears.
  4. Fasten the support plate to the water housing crossover to ensure proper engagement of the tool to the water pump locking ears.
  5. Remove or disconnect the following:
    • Pump from the housing:
      1. Use suitable water pump puller/installer tool (or special service tool J38816-A) to turn the pump clockwise
    • Support plate from the water housing crossover gm_car_cad_sev_wtr_pmp_rem.gif
    • Water pump
    • Seal from the water crossover
  6. Clean the sealing surfaces of the water housing crossover and the pump cover.
  7. Clean and inspect the water pump.
To Install:
  1. Install or connect the following:
    • Seal into the recessed portion of the water crossover
    NOTE: The notched locking ear must be in the 7 o'clock position.
  2. Index the water pumps locking ears with the tangs in the water crossover.
  5. Turn suitable water pump puller/installer tool (or special service tool J38816-A) counterclockwise.
  6. Torque the water pump
    • Torque to: 74 ft. lbs. (100 Nm)
  7. Remove the support plate from the water housing crossover.
  8. Install or connect the following:
    • Water pump cover to the heater return hose
    • Water pump cover to the water housing crossover
      1. Torque to 89 inch. lbs. (10 Nm)
    • Radiator outlet hose to the thermostat housing
    • Water pump drive belt
  9. Place the water pump belt shield in position.
  10. Install or connect the following:
  11. Fill the cooling system.
  12. Start the engine then idle until normal operating temperature is attained.
  13. Recheck coolant level and top off as needed.
  14. Test drive the vehicle.
Aug 17, 2010 | 1998 Cadillac Eldorado
WHAT TYPE OF WATER PUMP WILL I NEED FOR A 1997 CADILLAC SEDAN DEVILLE V8 ENGINE
First of all,you will need the Northstar waterpump removal tool, You can get this from most reputable auto part stores and looks like this :-
The following link shows a selection of different manufacturers.
http://www.bizrate.com/automotive-repair-tools/northstar-water-pump/
You need to remove the air filter housing and ducting to gain easy access to the pump.
Remove the shield covering the pulley and belt. The belt is easily removed by levering the tensioner pulley.
The water pump is located at the lower radiator hose manifold where you will also find the thermostat.Remove the manifold cover and you will see the water pump.
Insert the removal tool over the pump making sure it is locked in position.You will need to use a breaker bar on the removal tool and turn the tool CLOCKWISE to release the pump (1/4 turn), or if you imagine the breaker bar being vertical, push towards the windscreen of your car,it takes quite a bit of force to unseat the pump hence the use of a breaker bar.
As for the waterpump itself, DO NOT buy anything other than AC DELCO as they are the highest quality and is a genuine GM replacement part.
Water pump part number AC Delco 252707
Installing the new pump does not require as much torque as removing the old one.
Tighten the new pump to 73 ft.lbs. making sure it is seated properly before tightening.
Don't forget to clean out the water pump housing prior to installing the new pump and don't forget to include a new water pump gasket and housing cover gasket.
It is also a good idea to install a new thermostat while you're at it.
Regards.
May 03, 2010 | 1996 Cadillac DeVille
Special tool to remove water pump on 1999 cadillac deville
remove air filter housing,remove secondary air check valve bracket,if equipped,remove lower radiator hose from the thermostat housing,remove waterpump bypass hose, remove waterpump cover,use special tool to remove waterpump,install a new o-ring inwaterpump housing
Apr 10, 2009 | 1999 Cadillac DeVille
Replace left rear axle seal 1999 ford explorer
Axle Shaft Removal
  1. Raise and support the vehicle. For additional information, refer to Section 100-02 .
  1. Remove the wheel and tire assembly. For additional information, refer to Section 204-04 .
  1. Remove the differential housing cover (4033).
    1. Loosen the bolts and drain the lubricant from the rear axle housing (4010).
    1. Remove the bolts.
    1. Remove the differential housing cover.
Remove the rear brake disc (2C026). For additional information, refer to Section 206-04 .
  1. sxn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Turning the differential case (4204) or an axle shaft (4234) with the differential pinion shaft (4211) removed will cause the differential pinion gears (4215) to fall out of the assembly and damage the components.
    Remove the differential pinion shaft.
    1. Remove the differential pinion shaft lock bolt.
    1. Remove the differential pinion shaft.
  2. sxn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the rubber O-ring in the U-washer groove.
  3. Remove the U-washer (4N237).
  4. Push the axle shaft inboard.
  5. Remove the U-washer.
Reinstall the differential pinion shaft.
  1. Install the differential pinion shaft.
  2. Install the differential pinion shaft lock bolt finger-tight.
  3. sxn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the wheel bearing oil seal (1177).
    Remove the axle shaft.
Seal Removal
  1. Remove the axle shaft (4334). For additional information, refer to Axle Shaft in this section.
  1. sxn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Never remove the wheel bearing oil seal (1177) by itself. Always remove the rear wheel bearing (1225) and the inner wheel bearing oil seal at the same time.
    NOTE: If the wheel bearing oil seal is leaking, the axle housing vent may be plugged with foreign material.
    Using the special tools, remove the rear wheel bearing and wheel bearing oil seal together.
6c7eb46.gif Installation
  1. Lubricate the new rear wheel bearing.
    • For 4.0L SOHC and 4.0L EI with limited slip rear axles and 5.0L vehicles, use SAE 75W-140 High Performance Rear Axle Lubricant F1TZ-19580-B or equivalent meeting Ford specification WSL-M2C192-A.
    • For 4.0L SOHC and 4.0L EI with conventional rear axles, use SAE 80W-90 Premium Rear Axle Lubricant XY-80W90-QL or equivalent meeting Ford specification WSP-M2C197-A.
  1. Using the special tools, install the rear wheel bearing.
  1. Lubricate the lip of the new wheel bearing oil seal.
    • Use Premium Long-Life Grease XG-1-C or equivalent meeting Ford specification ESA-M1C75-B.
  1. Using the special tools, install the wheel bearing oil seal.
  1. Install the axle shaft. For additional information, refer to Axle Shaft in this section.
Feb 22, 2009 | 1999 Isuzu Rodeo
Need to replace faceplate for nokia 5300
Start by removing battery. Then remove the camera plastic panel. After that you will need to loosen the screws holding the faceplate in on the top. You will require a special tool for this but it can be purchased from most places that sell DIY faceplate kits.After careful prying the faceplate should come loose. Keep in mind that the screen over the LCD screen is taped on and will need to be removed separately.
Oct 24, 2008 | Cell Phones
Full faceplate installation instructions
take the phone to a mobile service center and have it done or try youtube.com but if you are not a professional pls do not try this as the ribbon that connects to the board is very fragile.
Mar 18, 2008 | Motorola Mobility RAZR V3
Faceplate
Found this on Howard Forums. Sorry no photos.
CHANGING HOUSING/FACEPLATE:
Take off your battery, unscrew the screws on the back of the phone with a T6 screw driver.
Pry off the back plate,lift up circuit board gently(be mindful of flex cable) remove the flex cable from mail board by lifting brown part by the connector,
Unscrew then next 2 set of screws(be careful of flex cable!) remove the LCD board from the faceplate.
Now put the LCD Panel into the new faceplate. Find the new back slide and put your sliding rails on.(you may also put the slide magnets on from the old housing) carefully thread your flex cable through the opening.
Snap the Back slider on and then screw in the screws, then take the keypad housing and screw it into the slide rails.
Reconnect the flex cable by putting the brown hatch up(gently with finger nail) gently feeding the cable into the connector until the white line is about to the end of the connector.
Then put the brown thing down and apply little pressure.
Put the mail circuit board back into the phone with the headset jack going in first.
Then snap it back into place.
Transfer your speaker over the the new back housing with the prongs facing up.
Then screw on the back housing.
Replace battery and your DONE!!!
Best of Luck.
Please RATE my solution BELOW.
Nov 25, 2007 | Kyocera Slider Remix KX5 / Sonic Cellular...
Putting on faceplate for samsung t319
hi you best bet is go to a repair mobile shop if are in doubt to try this .
you'll need a small Philips head screwdriver to complete the installation. To take off original faceplate, remove 2 screws located below the inside display (screws are hidden under stickers). Next, gently pry off the faceplate along the edges between faceplate and phone with a Faceplate Removal Pry Tool. When re-attaching screws, do not over-tighten screws
riz.
Aug 23, 2007 | Nokia 6288 Cellular Phone
Motorola Mobility C261 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
vince
Lawrence Oravetz
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
