Question about Toshiba SD-V392 DVD Player/VCR
Sansui VCR/DVD player combo. A Platinum Plus model
The DVD player starts, but then shuts down. It sounds like someone is reving a small engine ... it keeps trying to go ... and finally the error signal shows and it doesn't do anything. The red light ... that I am not to look into ... with the cover off ... I can see it blinking underneath the DVD and it won't settle it continues to move. Don't know if that is normal.
  • Par Breaker Jan 05, 2008
    Thanks for help!!
    Update: Adding additional info: I turned it on this morning and it worked. It played the movie for about 10 or so minutes and it froze. The T.V. is showing a still picture. I remember the timing of things ... I believe if I turn it off for a while and turn it back on it will work again for a short while.
  • 2,427 Answers
It moves cause its trying to read the disk.
the two main causes of this is that
1.) the disc isnt spinning fast enough 5000rpm is required for it to work
2.) the lens is damaged
in eighter case you'll need to replace parts..
you can take it into a technician if you like of you can try to fix it our self
if it aint spinning fast enough you have to change the motor
if the motor is fine then its the lens, try cleaning it and if that dont work replace it.
I'd recommend you get a new player cause the parts required is a bit hard to find, and it cost with the technicians labour almost as much as a new one
MY SIGGESTION is its disposable
Posted on Jan 05, 2008
Machine shuts down after 6 seconds of operation
Machine shuts down after 6 seconds... Answer Failed: retry DVD/VCR Combo was working fine then one day machine started shutting down after a few seconds of... (More) (More) DVD/VCR Combo was working fine then one day machine started shutting down after a few seconds of operation. It happens with both, a VCR and a DVD. I can watch 6 secs. of a movie at a time.
May 07, 2010 | Sylvania DVC840G DVD Player/VCR
Problems with Sansui VRDVD4005 DVD Player / VCR Combo.
the only problem i have is the remote reciever works only part time. I bought aa new remote control but didn't help.what do you think the problem is.
Mar 02, 2009 | Sansui VRDVD4005 DVD Player/VCR
Only dvd plays properly but vhs will not show picture.
Most likely you have the dvd part connected through component or svideo cables. Despite the fact that this is one unit, like other vcr/dvd combo units it acts as two separate units in the same box. The vcr will probably not play through those cables. As you have audio coming through I'd imagine that the audio is connected using red and white composite cable. Connect the video on the vcr side with composite yellow cable or run direct to tv with a coaxial cable.
Feb 04, 2009 | Sansui VRDVD4005 DVD Player/VCR
Schematic for the Sansui VRDVD4005 DVD Player / VCR Combo Sansui
Jan 07, 2009 | Sansui VRDVD4005 DVD Player/VCR
Sansui DVD Vcr combo wont play Dvd's model no. VrdVD4005
you will need to run a cleaning disk in it , if that won't work then it will have to be taken apart to clean the laser eye manually
which then if you can't do this then you will need to take it to a local repair shop where they can do it
Oct 26, 2008 | Sansui VRDVD4005 DVD Player/VCR
Sansui VRDVD4000
Universal remotes rarely fully work with these type of units. Call Orion customer service 800 289 0980 to price an original remote.
Oct 09, 2008 | Sansui VRDVD4000 DVD Player/VCR
NETFLIX DVD will not play ...
sounds like a region code block on your dvd player this is a risk unlocking region codes for player search internet explore region code for your model follow directions this is a use at own risk code
your dvd is region coded and your dvd player combo is region coded which code i dont know if live in united states the code for this region is one
May 17, 2008 | Sansui VRDVD4005 DVD Player/VCR
Toshiba SD-V392 DVD Player/VCR Logo
664 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
