Question about Casio EXILIM ZOOM EX-Z60 Digital Camera
Lens error I dropped my camera during new years and now the lens is stuck extended out. I can cut the power on to view my pictures, but cannot cut the camera on to take pictures. It says to try power on again, and when I do that it says lens error.
  • Casio Master
  • 4,738 Answers
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Jan 05, 2008
Dropped camera while it was turned on - now "lens error" appears on screen & can't turn off camera or view pictures
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Dec 25, 2010 | Nikon COOLPIX L20 Digital Camera
My camera wont take pictures. It will only turn on to let me view the pictures in the memory card. When I press the power on button, the lens comes out just barely, not all the way.
Sep 26, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Took a picture, then camera was in bag for a moment with lens open. when I tried to take another picture it was blurry, then the lens got stuck , "Lens error", kept making noises, had to take batteries...
What you're experiencing is called a lens error. Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Feb 18, 2010 | Nikon COOLPIX L3 Digital Camera
I can turn the camera on to look at pictures, but when I try to take a picture the lens is stuck and does not extend all the way. If I slide it over to view pictures, the lens extends fully and then...
If the camera has recently been dropped you may have lens damage that is preventing it from powering up. If it hasn't been dropped your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera and give them a full charge (assuming that you are using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, it may be time for new batteries, or the camera may have a problem that requires professional repair.
Dec 30, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
When i turn my camera on, its a blank screen with
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Oct 03, 2009 | Canon PowerShot A75 Digital Camera
Dropped my exlilim ex-s880 in the sand and can view pictures only
Jun 06, 2009 | Casio Exilim EX-S500 Digital Camera
I have the sd1000 power shot canon. i was taking a picture the camera took the picture as normal but when trying taking another shot i got an lens error restart camera.
One thing, you mentioned that the lens error occurred after you wer able to take a good picture. This really sounds like your battery ran down during shooting, and did not have sufficient power to properly shutdown the camera. Focus on your battery as the potential cause first. Note that if the battery is older than a couple years, it may be time for a new one. Rechargeable are not meant to last indefinitely.
Jan 23, 2009 | Canon PowerShot SD1000 Digital Camera
The lens will not retract. When in picture mode er18 appears on the otherwise blank screen. It will switch to allow me to view the pictures on the card
Oct 10, 2008 | Cameras
Lens is stuck
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're worth a try:
Feb 03, 2008 | Kodak Easyshare M753 Digital Camera
Les extended, screen remains black
tuen on camera then press display a few times. it sounds like the display is just turned off. the lens system should be open.
Jan 03, 2008 | Pentax Optio S50 Digital Camera
Casio EXILIM ZOOM EX-Z60 Digital Camera Logo
100 people viewed this question
Top Casio Cameras Experts
mohamed salim shaikh
pontelemon
pontelemon
Are you a Casio Camera Expert? Answer questions, earn points and help others
