Home | Frigidaire | (ATF6000ES) Front Load Washer | Frigidaire Washer Mod...
Frigidaire Front Load Washer
Problem for Frigidaire (ATF6000ES) Front Load Washer
Frigidaire Washer Model #WILL-1 - won't spin or pump out water
By s_verhelle on Nov 06, 2009
Frigidaire Washer Model #WILL-1: It won't spin or pump the water out...??? Manually spinning it did not help. Motor just hums now.
Best Solution
posted on Nov 06, 2009
Very Helpful)
nanbuenbrazo
Rank: Wiz  Washers & Dryers  Expert
Rating: 78%, 155 votes
Can you access the location of you motor?
try to open the back and unscrew the cover and see if you can see the motor, try to start it but don't get near to much just enought to see if it is moving or not.
if it still running and rotating see the belt maybe it is too loose or maybe it is to tight,
But if it just humming, turn it off and unplug, see if you can rotate the motor with your hand, if you can then you'll need a starting capacitor, you got to buy one and install.
But if it is hard to turn even without a load, then you'll need to bring your motor to a service center to check for the bushing and shafting and lubrication.
your motor winding is still ok since you heard a humming sound, that problem would be the mechanical part.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Nov 07, 2009
Not Rated)
ae7842
Rank: Apprentice  Washers & Dryers  Expert
Rating: 0%, 0 votes
is there a reset on the washer ,motor is fine ,belt is fine ,but it will not complete cycle it skips high speed spin at the end of cycle,clothes still wet ,just replaced water pump..
Was this helpful?
Yes
No
Popular Solutions for Frigidaire Front Load Washer
Questions and Unsolved Problems for Frigidaire Front Load Washer
Do you recommend Frigidaire (ATF6000ES) Front Load Washer?
Answer
Answer
model gltf1040ASO the motor will spin for the back and forth cycle but not the spin cycle...makes a... (More)
Answer
how do i rest the computer chip on my frigidaire washing machine?
Answer
There is a constant buzzing sound throughout the entire wash cycle. The clothes wash fine-just a... (More)
Answer
I have a Frigidaire Front Loading Washer (model # LTF6000FS0 ). It runs fine until the rinse cycle,... (More)
Answer
we are being warned about possible mold problems on our new Frigidaire front-load washer. How can we... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Frigidaire Front Load Washer:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14685
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
