Texas Instruments TI-83 Plus Calculator
Problem for Texas Instruments TI-83 Plus Calculator
I am getting the wrong answers with the tan -1
By xchellemarie on Nov 06, 2009
i am getting the wrong answers with the tan -1 function
Solution #1
posted on Nov 06, 2009
Not Rated)
k24674
Rank: Guru  Office Equipment  Expert
Rating: 88%, 790 votes
That habit of TI, Casio, and Sharp to label the inverse trigonometric functions with the -1 superscript can cause confusions.
  1. The inverse trigonometric functions arcosine, arcsine, and arctangent (labeled by manufacturers as cos^-1, sin^-1, and tan^-1) should not be confused with the other trigonometric functions known as secant(x) =1/cos(x), cosecant(x)=1/sin(x) and cotangent(x) = 1/tan(x).
  2. To avoid errors in the use of the inverse trigonometric functions, one must be careful and set the angle unit to the one required by the problem at hand (degrees, or radians)
  3. To make the trigonometric functions really functions, their range is restricted.
  4. In this calculator arcosine (x) gives results between 0 and 180 degrees (if angle MODE is Degree) or between 0 and Pi radians (if angle MODE is Radian).
  5. The range of results for arcsine(x) and arctangent(x) is between -90 degrees and +90 degrees (if angle MODE Degree) or -Pi/2 and Pi/2 (if angle MODE is Radian)
With this information you should be able to set the angle unit correctly ([MODE][Radian] or [MODE][Degree] ) and interpret the results. If you want to extend the angle to other values, use the periodicity of the trigonometric functions.
Hope it helps
Was this helpful?
Yes
No
Popular Solutions for Texas Instruments TI-83 Plus
Questions and Unsolved Problems for Texas Instruments TI-83 Plus
Do you recommend Texas Instruments TI-83 Plus Calculator?
Answer
Answer
how do you do fractions on the texas instrument ti-83
Answer
what is the meaning or mpa
Answer
a horizontal line streaks from the center of the screen upon turning the calculator on, then screen... (More)
Answer
I try to graph two parabola to find the intersect on my calculater but it wont graph
Answer
the text is patchy and is unable to be read clearly
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Calculator Experts
Top Copier & Fax Repairmen
in , IL
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
