Casio fx-300ES Calculator
Problem for Casio fx-300ES Calculator
How do i find the variance if i'm given the x
By ashiffman on Nov 06, 2009
How do I input x-values and their probabilities on my calculator to find the mean and variance?
Best Solution
posted on Nov 06, 2009
Very Helpful)
k24674
Rank: Guru  Casio Office Equipment  Expert
Rating: 87%, 677 votes
Set the [Mode] to [3:STAT]. You are offered the choices
1:1-Var
2:A+BX
3:__+cX^2
etc.
If you want to do 1-Var statistics, you press 1:1-Var. A column template opens where you put the X values. If a value is repeated you enter it several times. (there is no frequency column.)
When you enter all data you press [SHIFT][STAT]
You have several choices among them
4: SUM to get SigmaX^2 and Sigma X
5: VAR to get n, the mean X bar, the sample and population standard deviations
6:MINIMAX to get MinX and MaxX
7: Distr the Distributions.
If you want to perform 2-Var statistics
You press [MODE][STAT] and select one of the Regression models
2:A+BX
3:__+cX^2
etc.
The selection of any of the 7 regression models, opens a two-column template where you enter the X and Y values
When finished press [SHIFT][STAT]
The choices offered are
  1. Type takes you back to select type of statistics to perform
  2. Data To edit the data in the columns
  3. Edit To insert or delete a value
  4. SUM To access the calculated values of SigX^2,SigX,SigY^2,SigY,SigXY,SigX^3, SigX^2Y, SigX^4
  5. Var : To access the calculated values n, Xbar, Sample STD for x, S STD for Y, Pop STD for X, and Pop STD for Y
  6. MinMax : MinX, MinY, MaxX, MaxY
  7. Reg: Gives you the regression coefficients for the particular regression model you want to test.
The mean is represented by X bar.
The variance is the SQUARE of the Standard Deviation.
Hope it helps.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Casio fx-300ES Calculator
Questions and Unsolved Problems for Casio fx-300ES Calculator
Do you recommend Casio fx-300ES Calculator?
Answer
Answer
What battery to I buy for the backup battery in fx-300es?
Answer
whats the code of creating calculator in visual
Answer
Can you set the present value of a discount bond?
Answer
how do i change the exchange rate on my casio hs-85te tax & exchange calculator?
Answer
our teacher told us to make a scientific calculator using visual basic without disccussing on how to... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Casio fx-300ES Calculator:
Top Calculator Experts
Rank: Guru Guru
Solutions: 769
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Calculator Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
