Maytag Neptune MDG5500AW Gas Dryer
Problem for Maytag Neptune MDG5500AW Gas Dryer
The gas comes on and off and clothes do not dry
By cudds_1 on Nov 06, 2009
the gas comes on and off and clothes do not dry
Solution #1
posted on Nov 06, 2009
Not Rated)
Controlfrk
Rank: Guru  Maytag Expert
Rating: 95%, 95 votes
The service manual for your dryer, at the link below, will cover some troubleshooting information.:
http://www.mediafire.com/file/zrlyi1izwly/MDE5500
Assuming your gas is staying on and restarting each time the ignitor glows-the description below will likely lead you to a solution:
This is likely the result of an air flow problem if you are sure the heater is working properly. Ensure you are not running the dryer in a closed room which would starve the dryer of air dramatically reducing the air over the clothes even if the full length of your vent is brand new. Next, remove the vent hose from the rear of the dryer and check for strong air flow at the outlet. If it seems strong enough then run a vent through a window or out into another room and do one load in this fashion. If this resolves your problem the blockage exists in the vent line outside your dryer and disassembling dryer becomes unnecessary.
If not, ensure you have seen and touched every inch of interior dryer piping and hold the lint filter up to the light to be sure you can see through it. Disassemble and clean ANY section of piping you can't get your hand into. The area below the lint filter tends to catch a lot of lint and can only be accessed by removing the housing at the rear on the left side as you face the rear. Ensure the blower wheel turns when the motor turns. (Newer models may have the filter housing at the front)
Having performed all these actions will likely resolve the problem.
Was this helpful?
Yes
No
Popular Solutions for Maytag Neptune MDG5500AW Gas
Questions and Unsolved Problems for Maytag Neptune MDG5500AW Gas
Do you recommend Maytag Neptune MDG5500AW Gas Dryer?
Answer
Answer
Gas Dryer not going to high heat and blower not increasing speed either. Takes forever to dry... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dryer Experts
Top Washer & Dryer Repairmen
in , IL
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
