Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Whirlpool LSR8233EQ0 This Washer works well all the way up to the spin cycle after that it goes in to spin cycle and starts to go out of balance, stop and rearange the load and still goes out of balance... Any Tips Thanks Rick
  • 1 more comment
  • Anonymous Mar 16, 2014
    how do you stop washer from being out of balance with any type or size load on every spin cycle
  • Anonymous Mar 23, 2014
    Pva2300aww
  • Anonymous Mar 25, 2014
    Spin cycle has been getting louder and more vibration. Even with load rearanged.
  • 90 Answers
Check base mount springs, there are 3 from base to tub and 1 from tub to back bottom for counter balancing. If all are ok then you will have a skid plate problem. Best to call for help.
Posted on Jan 05, 2008
Maytag atlantis washer doesnt spin on spin cycle, also found plastic shavings in clothes, appear to be coming from the top outer edge of the tub, a white plastic trim piece. wash cycle seems to work fine...
There can be several causes, the drum off balance would cause the shavings during spin cycle , balance could be one of the the balancing mechanism failed and not running could be the balance sensor shutting down the spin cycle. You should start by checking the balance shocks .
May 14, 2011 | Maytag Atlantis MAV9750A Top Load Washer
When water drains and machine goes into spin cycle it starts to make a loud clonking noise. It sounds as if the drum is going to fly out of the machine.
I've experienced this on occasion. stop the washer, redistribute the clothes, etc. so it is evenly balanced. The "rocking" occurs when the balance is uneven.
Apr 10, 2011 | Kenmore Washing Machines
Washing machine goes thru the wash cycle then it stops, if I lift the door it starts again ,than stops. lift the door it starts than stops
It could be your out of balance switch is getting tripped before you try it again put in the spin cyc and see if it spins and drains the water if it does a odd sized load could be causing the failure.
Apr 09, 2011 | Speed Queen AWN542 Washer
Makes real loud banging noise when spinning!
you have to many clothes in it and your throwing it off balance you may have a blanket in there or something try to rearange your clothes see if that helps
Feb 24, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My washer goes into spin cycle byitself and when washing,if u r in spin cycle it sets for 14 mins thats good 4 mins into spin all knob lights start flashing and the screen says uL
One thing to understand is that this is a difficult problem to pin down and may end up requiring the control board to be replaced.
The UL or unbalanced load error is displayed when the control board senses an out of balanced load.
You don't indicate if the washer is actually out of balanced or not when the code appears but the description of banging and shaking would indicate it is out of balanced.
If the washer consistently bangs and shakes in spin then I's suggest you remove the spin basket and check under it for obstructions that might prevent the washer from spinning smoothly.
Jan 23, 2011 | Washing Machines
I have an lg washer wm2077cm and it goes off balance when the spinning cycle starts and the stops.
Sometimes if the heavy bed spreads or curtain may cause this problem. Switch OFF machine manually and restart after the spin stops.
If problem repeats.
Check springs or shock obsorber inside the machine. The tub will be suspended with this.
Mar 30, 2010 | LG WM2688HWM TROMM SteamWasher
Spin cycle goes out of balance even when empty.
The stem is bent or fractured or the bearing is shot. This is a rebuild job for a techo.
Oct 20, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Jet engine??!!
Friend,
ngafm at your service!
How old is the washer?
It sounds like the tire out of balance syndrome!
Like a car tire that sings or vibrates when it's out of balance!
It may be a worm part thats spinning and you should call service and not take any chances, with this matter!
How long has it been sounding like this?
Bless You
ngafm
Please give me a rating here at this site before you sign off!
Bless you
Please give me a good rating before you sign off !
Sep 05, 2008 | Frigidaire GLWS1439F Top Load Washer
Stops mid cycle
It may be a out of balance alarm during a spin cycle. Re-balance the clothes and hit start.
Jun 12, 2008 | Fisher Paykel EcoSmart GWL15
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
429 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
