Question about Philips 55PW9363 55" Rear Projection HDTV-Ready Television
How do I get my play station 3 to work on av 4 componet video inputs?
I have recently purchased a playstation3. I have a philips 60in.60PP9352 tv.The manuel says that the dvd player must be in progessive scan mode to play on the av4 jack, however, I can not figure out how or where you are to set up the playstation3 in order for it to play.When I set it up, all I get is lines on the television. I do get sound from the player on the tv. I can get it to play on another tv in the house. I am pretty sure that it has something to do with this progressive scan verus interlaced mode.
  • Anonymous Jan 11, 2008
    I also am having trouble hooking up PS3 to this TV. I am trying to use the composite video inputs. I know they work because DirecTV is hooked up to them. When I switch the wires to PS3 I get the same problem you are describing here. My solution was to try to get a DVI/HDMI adapter and try hooking up the PS3 through AV5. I will let you know if it works. Let me know if you have any luck.
  • mooseass Jan 11, 2008
The problem is definitely with the set up of the PS3. If you have another TV in the house that the PS3 works on this is good. This will make your life a lot easier. Set up the PS3 on that TV. In the system settings for the PS3 go to the video settings. The TV in question does not support 720 resolution. This TV only works in 480i 480p and 1080i. Make sure that these are the only three boxes checked and everything should go fine.
Posted on Feb 29, 2008
Ioio
Posted on Feb 28, 2008
    Problem Solver:
  • 18 Answers
The simplest solution is always the easiest to try. Unplug the video cable of your dvd player. Plug your PS3 video cable in and test.
Posted on Jan 05, 2008
Can't get the play station to work with the tv. The av is plugged in correctly and the ps is turned on. Don't know which channel to go to, and when EXT we tried all different inputs and it still doesn't...
Which generation playstation are you referring to The PS2 or PS3. The PS2 would be connected with a composite cable by default i.e red white and yellow cable. Connect the cable to the corresponding input on the TV, match color codes. Switch to correct input by using your remote controller. Press the AV button and a list of inputs come's up.Select av1 or av2 and check if you get a picture. If you use a ps3 then same as before press AV button on remote and select appropriate option on screen HDMI,Component or Composite.
HDMI looks like this
Component
And Composite
Jan 16, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
HOW TO SET UP REMOT TO VIDEO CHANEL,I CAN,T CHAN THE CHANEL TO THE VIDEO CHANEL
Hello
Audio and Video Front Inputs are available
for a quick connection of a VCR, to playback
video from a camera or attach a gaming
device. Use the AV button on the remote control
to tune these inputs.
1 Connect the video (yellow) cable
from the Video output on the Camera
(or accessory device) to the Video (yellow)
Input located on the FRONT of
the TV.
2 For Stereo Devices: Connect the audio
cable (red and white) from the Audio
Left and Right Outputs on the Camera
to a Stereo to Mono adapter. Then plug
the single end of the adapter to the
Audio In (white) jack on the FRONT
of the television.
For Mono Devices: Connect one end
of the audio cable from the Audio Out
jack on the device to the Audio In
(white) jack on the FRONT of the television
3 Turn the TV and the accessory device
ON.
4 Press the AV button on the remote
control to tune the TV to the side input
jacks. "Front" will appear on the TV
screen.
5 Press the PLAY  button on the
accessory device to view playback, or
to access the accessory device (camera,
gaming unit, etc.).
Repeatedly pressing the AV button on the
remote control will toggle the picture source
from the current channel, or Front input
jacks.
Note: The Audio/Video cables needed for
this connection are not supplied with your
TV. Please contact your dealer or Philips at
800-531-0039 for information about purchasing
the needed cables
OK
Jan 06, 2011 | Philips 20PT633R 20" TV
How do i connect a playstation 3 to a philips tv
The PlayStation 3 (PS3) is a high-definition gaming console that supports both standard AV connections and high-resolution connections (such as HDMI). Most of the older Philips TVs come with a standard AV input. Newer, flat-panel Philips TVs include standard AV inputs and high-resolution inputs. To get the best video quality out of your PS3, using an HDMI connection is recommended if the option is available. The PS3 does not include an HDMI cable, only a standard AV cable
Standard AV
  • 1 Turn off the PS3.
  • 2 Connect the flat end of the PS3 AV cable into the "AV Multi Out" port on the back of the PS3.
  • 3 Connect the "red," "white" and "yellow" prongs on the opposite end of the PS3 AV cable into the corresponding "red," "white" and "yellow" AV inputs on the TV (usually located on the side or in the back).
  • 4 Press the "Source" button on the Philips TV remote.
  • 5 Select the "AV" video display mode.
  • 6 Turn on the PS3. The PS3 logo will appear on the screen.
  • HDMI Connection
    Dec 08, 2010 | Philips Televison & Video
    What channel does the tv need to be on to operate the dvd player? The dvd player comes on but it doesn't recognize the button commands on the tv-do no have the remote.
    channel 3 or 4. if that doesnt work switch the input on the tv. the input button might be labelled input/source/tv-video or av. if you arent getting a pic while the dvd player is playing look at the back of the tv and see where the cable from the dvd player is going into the tv. it is labelled what input it should be on. ex: video 1, etc. hope this helps.
    Jul 11, 2010 | Philips Magnavox 20MC4304 20 in....
    How do you connect a Nintendo 64 game station with 3 cables (Red,White and Yellow) to a Dynex Television. We tried the input options on the back of the TV. On the menu we selected both Channel 3 and...
    connect the AV cable to the red white and yellow input outlets on the tv and press input on your remote you have to be on video 1, 2, or 3 to play the nintendo 64
    Dec 26, 2009 | Dynex DX-L22-10A 22 in. LCD TV
    How can I hook this cam up to my Television?
    For this camera you will need to find in your equipment (or purchase) a "stereo video cable "
    This cord features a 1/8th (male) headset jack on one end and 3 male RCA jacks on the other. (yellow/red/white).
    Plug the 1/8th jack into the camera's AV input and the RCA plugs into your TVs RCA port input and select the correct AV input (AV 1, 2, etc)on your tv selector and the camera should play through your tv.
    Nov 04, 2009 | Canon ES75 Camcorder
    PS3 won't show up on tv
    first make sure all componet cables match up in color in back of the tv turn on ps3 and try using the remote to change the componet selection of the port your using
    May 14, 2009 | Sony Playstation 3 (PS3) Console
    Playstation3
    when the ps3 is in standby mode with just hte red light on. hold it down til it beeps takes about 5 to 10 seconds and it will bring it back to AV mode so u should be able to get picture and sound.
    Oct 31, 2008 | Sony Playstation 3 (PS3) Console
    Philips 26
    There is an input imbalance. Either try connecting your cables to different inputs on your TV, or try connecting to different outputs on your DVD player. (Only worry about the yellow video cable bit initially). Alternatively, try a different cable type; you'll have some ins and outs that don't use RCA connectors.
    Mar 03, 2008 | Philips 26PF5521D 26 in. HD-Ready LCD...
    Philips 55PW9363 55" Rear Projection HDTV-Ready Television Logo
    118 people viewed this question
    Top Philips Televison & Video Experts
    matt martin
    matt martin
    Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
