Elec. intertherm FURNACE
I HAVE A INTERTHERM FURNACE AND IT WANTS TO STAY ON ALL THE TIME. WE HAVE CHANGED THE THEMO. BUT THAT DID NOT HELP ANY. TO TURN IT ON WE HAVE TO TURN IT ON AT THE BREAKER AND CUT IT OFF AT THE BREAKER. IF WE DID NOT DO THIS IT WOULD RUN 24/7 PLEASE HELP...........
  • james prentice Oct 19, 2008
    Hi, we have an Intertherm electric heat/ac unit in our 99 Fleetwood double-wide.We awoke to an electrical shortage smell,the coils were red hot and cycling on and off with the fan off and temp reached,still heating,only shut off seconds when thermocouple?( safety pops ),then comes back on heating every 20-30 seconds! Whats parts are stuck or burnt out! Help,disabled ,moms terminal and we must repair myself!
    Sergeant:
  • 288 Answers
It would help if I knew what type of system you have, lets start with the thermostat. If you disconnect the wires to it, does the heat turn off? I have seen thermostat wires pinched inside the wall, thus bypassing the thermostat controls altogether and it would run constantly. If you send a reply, tell the type. Wall furnace, central unit, heat & cool, gas, electric or heat pump. If you dont know tell me how many wires you have at the thermostat and the colors. You should know this, as you have changed it.
Posted on Jan 13, 2008
  • masterohwise Nov 15, 2010
    i have this exact problem...4 wires and the last red wire has a jumper to the next.also when i turn the switch on the unit itself to fan instead of auto,it seems to go to a higher speed.we have not changed anything out except the thermo....
I have a Intertherm furnace model# MGH-065-ABRN-05...The target burner needs to be replaced. I type in my model # and it isn't reconized. Is this a good number. Thank You
I don't think that is a good model #. Here is a link to their site and the furnace models there have a totally different type of #.
http://intertherm.net/Products/Furnaces/GasFurnaces.aspx
If you really need the burner, Id call Intertherm and then they can tell you what data plate you should be looking at.
http://intertherm.net/DealerServiceLocator.aspx
Jan 02, 2018 | Intertherm Heating & Cooling
I HAVE A MODEL UFG-101AG-4 SERIAL # 800H2 INTERTHERM FORCED AIR FURNACE FOR MOBILE HOME OR TRAVEL TRAILER THAT I DONT KNOW WHATS WRONG WITH IT?
OK. Let me answer you, even if honestly I don't have any idea about an INTERTHERM FORCED AIR FURNACE. To get any answer, to a problem, you should describe your problem. Just telling that you don't know what's wrong with it is simply no enough information, even for a star expert in your INTERTHERM FORCED AIR FURNACE.
Jun 25, 2015 | Intertherm Heating & Cooling
My intertherm elec. furnace will sometimes not come on when the thermostst activatesit, I have to trip and reset the curcuit breaker then it will work ok for a day or so, where do I start to look?
It could be several things,a weak transformer,a poor connection, bad relay. I would contact Intertherm with your particular model number. http://www.intertherm.net/
Jan 15, 2015 | Heating & Cooling
Furnace won't stay lit. Intertherm Model M2RC-080A-16BN. Ignightor glows, flame starts and after a few seconds the flame shuts off. Then it starts the cycle again. It goes thru this cycle a fe
It sounds like the flame sensor is bad. If thats not the case you may need to replace the control board. You should make sure the flame sensor is directly into the flame.
Nov 20, 2014 | Intertherm Heating & Cooling
Intertherm propane furnace will not stay on
your machine is missing the oxygen check your ventilation,
1. try to turn it for 1 minute with leaving the door open.
Mar 24, 2014 | Intertherm Heating & Cooling
Intertherm electric furnace modular home
Will be to clean each contact-switch and scrape the contacts and use wd40 and spray of air and remove all rust, its possible that exist another options of failure.
Jun 17, 2012 | Heating & Cooling
Have an Intertherm thermostate in mobile home controlling gas hearing and elec ac. Blue wire to thermostat connects to the "A" terminal on the thermostat...Blue wire goes to a terminal on the...
If there are only two wires going to the thermostat? Then you will not be able to use a Digital Programable stat. Intertherm and Coleman furnaces do the switching different than regular furnaces. They use the switching from heat to AC at the furnace with the rocker switch. They use the thermostat to either break the connection or make the connection. They use a heating only thermostat.... Hope this helps
Jan 02, 2011 | Intertherm P3RA-048K Air Conditioner
Furnace won't stay on
Flame sensor could be dirty. It is located right beside the last burner looks like a thick piece of wire. Take steel wool and gently clean the probe 4 or 5 strokes is all it will take to take off the carbon build up off. Lets eliminate this item and see if it clears up okay. ken
Dec 21, 2008 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
366 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
