I have a Kenmore Elite HE3 that has plastic pieces breaking off and falling into the washer. It is coming from a part that is inside the front door gasket and it loks like the tub is supposed to ride on top of it. Can this part be replaced? If so what is it called?
Mine had the same problem. It also loudly vibrated at high speed spin. I took it apart and found the basket support that bolts to the back of the basket(this is what drives the basket) had corroded and broke one of the three arms off. It would work normally but at high speed it wobles. This is what causes the basket to rub the plastic and chew it up. I have to replace the front outer tub and the basket, about 500.00 in parts. if you have it done much more.
I can't solve the problem, but my HE3 42824 has done the exact same thing...the kenmore subcontractor repair people have been less than helpful and want to charge 180 just to come out and service it. We were told on the phone that it MAY be the plastic tub, and it MAY be covered under warranty. After waiting 5 days for a maintenance appointment, only to have them cancel it for 5 days, we had enough...I we bought a Samsung last night! I don't think the Kenmore cleans well, anyhow, and it adds a bit of a musty smell to my clothes, so I am glad to be rid of it!
Was this helpful?
Yes
No
Popular Solutions for Kenmore Elite 45986 Front Load
from a power surge i am pretty sure I have a circuit board out. I have a whirlpool duet GHW9150PW0...
(More)
from a power surge i am pretty sure I have a circuit board out. I have a whirlpool duet GHW9150PW0 front load washer. There is a main c board in the back and thenm the one behind the control panel. how can I tell which one is out , or what is the more likely one?
i have had a kenmore elite smartwash for 2 years -- I do not have it stacked. I just started a load...
(More)
i have had a kenmore elite smartwash for 2 years -- I do not have it stacked. I just started a load and after 10 seconds or so, I received the F20 error code. what should I do?
Our Kenmore Elite HE3T washing machine isn't spinning clothes. It makes sort of a groaning sound...
(More)
Our Kenmore Elite HE3T washing machine isn't spinning clothes. It makes sort of a groaning sound when it is supposed to be spinning. There is a small amount of water in the bottom of the washer and the clothes are wet. There has been an F02 code and we followed the instructions to check the drain hose. What is likely the problem? Can I fix it, or will it require a repairman?
