If the computer has a built-in recovery program then you can use that to bring the laptop back to factory settings. You can usually activate it by pressing "alt" then "f10" when computer first turns on but it may be different for your pc. Otherwise you can use a Windows installation disc to re-install another copy of Windows. This might erase all your files on the system by doing this. Or you can try and order a replacement disc from Toshiba. If you are going to use a Windows disc to re-install Windows then you will need to make sure the first boot device in the BIOS is the cd-rom drive so the computer will see the disc and boot the installation files. And if you get your computer up and working again be sure to create a recovery disc and keep it in a safe place.
you can order a cd or posibly download it from toshiba...... you have license for windows software either xp or vista and you can use the product number you own with a barrowed cd or burnt cd thats not illegal and you can goto toshiba download all the drivers off their website but your going to need a cd of some kind to reinstall it unless the recovery partition is still in good shape on the harddrive when you first turn the laptop on it should tell you something like for recovery options press F2 or ESC or something F10 its diffrent on each model if you have an owners book it will tell you exactly which key alows you to inter the recovery partition
my sisters A205-S5804 laptop keeps shutting down but only when it's processing files..If it's idle...
(More)
my sisters A205-S5804 laptop keeps shutting down but only when it's processing files..If it's idle it sits there for hours
A215-S4747, the computer is on, but the screen is blank and we can't get it to work. PLease be...
(More)
A215-S4747, the computer is on, but the screen is blank and we can't get it to work. PLease be something simple. What could be the reason?
Hello, I got a Toshiba A205-S5804, as long as it was used I'd erase all from the hard disk with the...
(More)
Hello, I got a Toshiba A205-S5804, as long as it was used I'd erase all from the hard disk with the recovery disk. The problem know is when I try to run the recovery disk it gives me a message: ERROR 08-064B-000 PARTITION CREATION FAILED And then the computer shut down. Please help me
My web cam will start up and if it doesnt say that it is locked by another program i will see myself...
(More)
My web cam will start up and if it doesnt say that it is locked by another program i will see myself , but its kind of a grainy picture. if i move the screen it will shut off or if i put my finger too close to the camera it will shut off. also i was on windows messenger the other day and it worked fine, now it will not work at all. any idea's???
