Question about Mitsubishi HS-U447 VHS VCR
A/B Remote functions
Is there a simple mod for the remote to switch to the B codeset? I use two HS-U447s in a single setup. Having to switch codes on the VCRs for programming is a pain.
  • 78 Answers
If you have your manual that came with it, it should have instructions on how to use the aux mode on the remote to work a second tv, vcr etc.
Posted on May 02, 2008
My pause, rewind and fast forward not working when watching tv
I ASSUME you are using the dvr function of a cable box or satellite receiver. I also ASSUME your other buttons are working, since you say nothing about them.
Check that pause, rew, and ff buttons have codes from the correct device. A code from your tv will not help if you need to control your sat receiver.
There may be multiple codesets in the Harmony database that work with your device, try all of them.
Sometimes the codes are poorly named or even wrong. You may need to try all the codes to find the right one.
I'm not sure if the Harmony One can learn codes from the original remotes, but that may be a better option.
Apr 10, 2015 | Logitech Harmony One LCD Touchscreen...
Durabrand remote codes Mod.1905Code
0382,0381. Try these codes. If you wish to get more codes and other details check: It has setup code list, and setup procedure to many popular brand remote controls. Check the site in 'Mosaic' view. It will make search easy.
Jan 03, 2014 | Televison & Video
I have a new urc 189100-08r00 need codeset list support
If you wish to get more information, check these links. Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
Dec 16, 2013 | Televison & Video
Can't get the tv to switch from cable to antenna mode using a RadioShack remote or the buttons on tv
It sounds that the front panel controls are locked with your tV. You have to unlock it first, if you want to change its input selections. If you cannot select the inputs by using the remote control [I thing you are using a universal remote control], setup the remote control with an other setup code. All codes to remote control won't work with some functions. You have to search and select, which code give maximum functionality with your TV.
Jul 06, 2012 | Zenith SY2569X TV
Looking to obtain a HS-U448 manual and remote.
The manual is available from the Mitsubishi Support site: . The direct link to the manual is .
The original remote is no longer available. However, has a substitute remote: .
A number of universal remotes will probably also work. The codes will be in any remote that still controls a VCR if the remote was programmed after the HS-U448 was released.
I hope this helps.
May 27, 2011 | Mitsubishi HS-U448 VCR
How do i program my RCA control to my direct tv box
According to Direct TV tech I just got this response "There are no working codes for the current rca models, reason rca folled around with codeset so all previuos rca codes in all remote are useless. Get an aftermarket learning remote."
Nov 25, 2010 | RCA DIRECTV Satellite Remote Control
My cable tv remote will turn this unit on with the codes supplied for the remote. But the remote will not control the volume or turn the unit off. Is there another code, or is this a problem with the cable...
There has to be another code and when you find it you will probably have to "lock" your remotes volume control to your audio device not the cable box (set-up that way from cable co) once you do that the cable box will be controlled from the remote(channels) and the audio will be controlled by your receiver from the same remote without even having to switch functions.. ask your cable company for a setup guide for your remote they will probably have a copy online.
Nov 27, 2009 | Onkyo TX-SR606 Receiver
No manual or remote
Following the instructions I have been able to program a Philips SRU4105WM/17 universal remote using the first Mitsubishi code from the code list. However, I had to have the universal remote "learn" the vcr/tv button function (I assigned it to the Exit button). Good thing I still have the original Mitsubishi remote:-) I haven't tried having the universal remote learn all the functions, such as Cancel, Counter Reset, Audio Function, Video Function etc. I could see if I'm able to program those, if you'd like. LMK if you have any other questions.
Mar 30, 2009 | Mitsubishi HS-U560 VHS VCR
Remote control doesnt work
Go to the manu and try new remote code, Hopefully by changing remote code, from Codeset 2, to code set 1
will solve your problem.
Jan 17, 2009 | Panasonic DMR-HS2 DVD Recorder
Mitsubishi HS-U447 VHS VCR Logo
74 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
