GE 24 in. Profile PDW7800 Built-in Dishwasher
Problem for GE 24 in. Profile PDW7800 Built-in Dishwasher
Acts like water is turned off to machine. turns on
By nstohlmann on Nov 06, 2009
acts like water is turned off to machine. turns on to run cycle but no water comes out. valve is on
Solution #1
posted on Nov 06, 2009
Not Rated)
shastalaker7
Rank: Guru
Rating: 89%, 63 votes
Turn the water valve off, and remove the hose. Where it screwed on, there should be a filter screen. This is more then likely to be clogged up. Clean this and try again after you put the hose back on.With the dishwasher in the fill position, and still pulled out, you should be able to hear the water fill valve coil open up.If you still have no water after cleaning, more then likely your fill valve is clogged or the coil has failed and needs to be replaced. 120volts,ac.Please let me know as I am here to help you. Good Luck, Shastlaker7
Was this helpful?
Yes
No
Popular Solutions for GE 24 in. Profile PDW7800
Questions and Unsolved Problems for GE 24 in. Profile PDW7800
Do you recommend GE 24 in. Profile PDW7800 Built-in Dishwasher?
Answer
Answer
It won't begin the cycle. The counter works but not the washer. I checked the water it's on but no... (More)
Answer
profile dishwasher...the time doesn't correspond to the cycle selected (e.g. i press the normal... (More)
Answer
ge pdw 7880 does not drain, even into a bucket straight from the outlet pipe
Answer
when i shut and lock the dishwasher to start it beeps non stop and will not start
Answer
My ge profile dishwasher sometimes leaves the top shelf dirty as though it sprayed trash on it at... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE 24 in. Profile PDW7800...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 905-9505
A&E Factory Service is a nationwide leader in...
A&E factory service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
