RCA RC5510P DVD Player
No audio
posted by sepi2008 on Jan 05, 2008
I have a new Westington HDTV and an older DVD player RCA RC5510P. I can't get any sound from the dvd player I purchased a RCA audio cable but I still can't get any sound, no matter where I plug this damn cable...(sorry I'm frustrated) HELP
Comment posted on Jan 05, 2008
The DVD player has sound with my regular headphones.
This is the back of my DVD player
Right side of the TV which is where I have the RCA audio cable inserted (per instructions in the manual)
The left side of the TV. I tried plugging on this side too, but no luck.
Not using the RCA cable, just a regular headphone jack to the front of the VCR.
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
Helpful (85)
Stonebraker
Rank:Wiz Wiz
Rating: 84%, 108 votes
Here's what I'd do:
Determine if the DVD player is in fact outputting sound by:
-Plugging the DVD player in to a couple TV's with as many RCA cables as you can
See if TV is accepting RCA audio:
Try anything else you have with the RCA cables (other DVD players, old VCR, Headphone -> RCA adapter (then you could use an ipod/computer/whatever to output a good sound source))
Also, I know with a lot of HDTV's you have to push the cables in pretty hard.
Which output are you using on your DVD player to get sound to your headpones? The RCA jack?
if you have an amp you could probably get audio that way...
do you have a spare vga cable? Usually you can hook up the VGA cable and and a standard headphone jack for sound (which you would use the RCA to headphone jack adapter)
Also, you can buy a cheap HDMI cable online for like $20
Or buy an optical cable.
Comment posted on Jan 06, 2008
Does your TV have a headphone jack?
Try DVD -> TV with this:
or
DVD -> TV with this
Some TV's will only accept the 3.5-mm stereo plug (that is the standard headphone plug for all mp3 players, computers, etc) if the TV is in a specific INPUT mode so try them all
.... ACTUALLY
If you can get sound through your VCR player.... do this
Use the DVD -> VCR like you did before, then VCR Audio out to TV Audio in ... it's pretty ghetto but it might work!
Rating Locked! (?) sepi2008 has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on no audio:
I don't want to Accept this solution
Solution #2
Thanks for Trying (70)
DARKLORD1
Rank:Guru Guru
Rating: 85%, 424 votes
yeah sometimes we all get fustrated with stuff like that, the trick is not to hit the thing with a hammer,,
any way ensure that yougot the cables connected propperly in the L/R audio output from the dvd player (RED AND WHITE its alo labeled) and connect it to the in in the tv..
check your player settings (audio settings and and check your tv audio settings to ensure they match) some HDTV's only use 5.1 or higher
if your dvd remote got a volume controll on it ensure the u\volume is all the way up and that it isnt muted.
try your player on a next tv to ensure its working , if it is the problem is with your settings as stated above
Rating Locked! (?) sepi2008 has rated this solution as Thanks for Trying
Thank You!
Can you Help with these DVD Players problems?
DVD Players
Is there a code to make my samsung dvd5500 combo become a...
DVD Players
i bought one halo 2 cd but lost the product key.i need a...
DVD Players
Hi. I have a Panasonic SA-HT75 home theater. It stopped...
DVD Players
can't find my instruction book. how do i finalize the disk...
when i insert a disc it will show loading, but wont...
Loading problems.
Repair Service
Find DVD Player Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Home Media Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
