Underneath the drawers in my fridge it collects water. I have to take a towel every few days and mop up the water or it leaks from underneath the door.
Hello there: I have written a few steps for you to follow and try ok?
Manufacturers
have different ways to dispose of the water created during automatic
defrost cycles. The most common design routes the water down a rubber
tube on the back of the fridge to a tray beneath. This tube often gets
plugged with breadcrumbs, peas etc. and can generally easily be removed
and cleaned.
Make sure the end of the hose is sitting in the defrost tray.
If
your hose was not plugged and you have found water running down the
back wall inside the fridge or a pool under the bottom crisper has
formed. Check if there is a small funnel located on the back wall near
the top inside the fridge. It can also get plugged; you can use a small
wire and work it in and out of the hole.
Some designs do run the water down the back wall and have a drain hole under the crisper, make sure it is not plugged.
I hope that this has been verry helpfull for you best regards michael
cannot remove existing water filter unit from frigidare galler side by side refrigerator in order to...
(More)
cannot remove existing water filter unit from frigidare galler side by side refrigerator in order to install new pure source water filter
Our 12 year old Gallery refrigerator has not been keeping the refrigerator side cold....Inside temp....
(More)
Our 12 year old Gallery refrigerator has not been keeping the refrigerator side cold....Inside temp. is 54-56 degrees. Time to buy another refrige?
Is it normal for a 1 year old to run for 3-4 minutes than stop for 10-12 minutes and began the cycle...
(More)
Is it normal for a 1 year old to run for 3-4 minutes than stop for 10-12 minutes and began the cycle over again
Glgfs66csb stove was never kept clean and the spills have baked on. I've tried everything, even...
(More)
Glgfs66csb stove was never kept clean and the spills have baked on. I've tried everything, even easy-off oven cleaner. What can I use to get it clean again.
I took the bottom shield off the bottom of my dishwasher. It came off in 2 parts - an upper and...
(More)
I took the bottom shield off the bottom of my dishwasher. It came off in 2 parts - an upper and lower part. Putting the lower part on is a cinch, but I can't figure out how to reattach the upper part.
