Problem for Dell Dimension C521 PC Desktop
I need a diagram of how to get inside my C521 to
I need a diagram of how to get inside my C521 to put in additional memory modules. I have 2 1GB modules that I just purchased from Dell. I don't have a manual with instructions on how to get into the computer
Best Solution
posted on Nov 06, 2009
Rank: Guru
Expert
Rating: 89%, 376 votes
Locate the cover release latch on top of the computer, near the back. Place the computer on its side, with the removable cover facing upwards. Slide the cover release latch back and lift the removable cover off of the computer. This video will show you exactly how.
Was this helpful? 1 person thought this was helpful
Solution #2
Rank: Guru
Rating: 86%, 162 votes
Good day sir/maam, you need to open the side cover of the dell PC, now look at the picture below:
Turn the PC off, the encircled part is the memory slot, on its side is the release/locking lever, place the lever in the release (push it on the side) now insert the module vertically with then gently push it down until the lever snaps into lock. Do it with the next module, takes a little practice, if the module is snug and fit. thats it. Power on the PC. if you hear continuos
beeping, power the pc off, remove the modules and do the installation again. Do this several times until the PC response.
Solution #3
Rank: Wiz
Expert
Rating: 79%, 858 votes
From the manufacturer's web-site:
http://support.dell.com/support/edocs/systems/dimc521/en/
under "Service Manual", click "View".
Click "Removing the Computer Cover".
Look at the pictures & instructions.
Before you install the RAM, it is important that you select
the "Removing and Installing Parts" section,
and read how/where to put your 2 sticks of RAM
into some of the 4 slots on the motherboard.
Solution #4
Rank: Wiz
Rating: 82%, 31 votes
Popular Solutions for Dell Dimension C521 PC Desktop
Questions and Unsolved Problems for Dell Dimension C521 PC Desktop
Do you recommend Dell Dimension C521 PC Desktop?
i m a windows xp user i want to download a .sis file plz can u help me out?
Need to separate main case to repair DC socket. Cannot find last screws? around socket. Seems 2...
(More )
Need to separate main case to repair DC socket. Cannot find last screws? around socket. Seems 2 halves are glued together? Can you supply a disassembly instruction pdf, or a sevice manual?
have an older jiffy ice auger its starts, but does not stay running. when i start it, it runs and...
(More )
have an older jiffy ice auger its starts, but does not stay running. when i start it, it runs and while running i push the primer and it stays running. then when i stop pushing the primer it stallss. how do i fix this
don,t write DWD-R+R-RW disk SH-S222A WinXP3, CD-R,RW ok ...
(More )
don,t write DWD-R+R-RW disk SH-S222A WinXP3, CD-R,RW ok Тип компьютера Компьютер с ACPI Операционная система Microsoft Windows XP Professional Internet Explorer 6.0.2900.5512 DirectX 4.10.0.18000 (DirectX 10 Дата / Время 2009-12-17 / 20 Системная плата Тип ЦП Intel Pentium 4, 1978 MHz (18 x 110) Системная плата DFI NB72-SC/SR (5 PCI, 1 AGP, 1 CNR, 3 DIMM, Audio) Чипсет системной платы Intel Brookdale i845 Системная память 512M 133MHz Тип BIOS Award Modular (11/14/01) Коммуникационный порт Последовательный порт (COM1) Коммуникационный порт Последовательный порт (COM2) Коммуникационный порт ECP порт принтера (LPT1) Отображение Видеоадаптер NVIDIA GeForce4 Ti 4200 with AGP8X (128 Мб) Видеоадаптер NVIDIA GeForce4 Ti 4200 with AGP8X (128 Мб) 3D-акселератор nVIDIA GeForce4 Ti 4200 with AGP8X Монитор Samsung SyncMaster 703(M)s/750(M)s/753(M)s/MagicSyncMaster CM173A(M) [17" CRT] (HSBX208190) Мультимедиа Звуковой адаптер Realtek ALC200(P)/ALC201(A) @ Intel 82801BA ICH2X - AC'97 Audio Controller [C-0] Хранение данных Контроллер IDE Intel(R) 82801BA Ultra ATA Storage контроллер - 244B Контроллер хранения данных A2CH9WBD IDE Controller Дисковый накопитель ST380011A (80 Гб, 7200 RPM, Ultra-ATA/100) Оптический накопитель GG3924Z UGQ028O SCSI CdRom Device Оптический накопитель TSSTcorp CDDVDW SH-S222A (DVD+R9:16x, DVD-R9:12x, DVD+RW:22x/8x, DVD-RW:22x/6x, DVD-RAM:12x, DVD-ROM:16x, CD:48x/32x/48x DVD+RW/DVD-RW/DVD-RAM) Статус SMART жёстких дисков OK Разделы C: (NTFS) 12000 D: (NTFS) 64307 Мб (41374 Мб свободно) Общий объём 80000 Ввод Клавиатура Стандартная (101/102 клавиши) или клавиатура PS/2 Microsoft Natural Мышь PS/2-совместимая мышь Сеть Первичный адрес IP [ TRIAL VERSION ] Первичный адрес MAC 00-21-91-91-05-7B Сетевой адаптер D-Link DFE-520TX PCI Fast Ethernet Adapter (192. [ TRIAL VERSION ]) Периферийные устройства Контроллер USB1 Intel 82801BA ICH2X - USB Controller 1 [C-0] Контроллер USB1 Intel 82801BA ICH2X - USB Controller 2 [C-0] DMI DMI поставщик BIOS Award Software International, Inc. DMI версия BIOS 6.00 PG DMI производитель системы DMI система DMI системная версия DMI системный серийный номер [ TRIAL VERSION ] DMI производитель системной платы DMI системная плата i845 DMI версия системной платы DMI серийный номер системной платы [ TRIAL VERSION ] DMI производитель шасси DMI версия шасси DMI серийный номер шасси [ TRIAL VERSION ] DMI Asset-тег шасси [ TRIAL VERSION ] DMI тип шасси Desktop Case DMI всего / свободных сокетов памяти 3 / 1
I have SRB90 but I dont know how to operate? I try to swipe my Card but cannot read.Help me
