Did you clean the mesh screen filter in the end of the hose where it connects to the valve. It can stop up with sediment.
Comments:
Nov 06, 2009
- The water inlet valve is on the other end of the incoming water hose on the back.. It's usually blue and each side works independent of the other according to the water temp. selected. If the water flows good coming out of the valve then the problem is else where. Look for kinked water line etc.
its a filter inside the water hose thats still blocked or the relay inside the washer for the cold feed is not opening up fully it could just need a clean or maybe a new one fitted
Was this helpful?
Yes
No
Popular Solutions for Kenmore 22422 Top Load Washer
I've had a Kenmore 20422 for a while now, and the spin cycle does not start correctly. I have to...
(More)
I've had a Kenmore 20422 for a while now, and the spin cycle does not start correctly. I have to open the lid, move the tub while holding down the switch, and it will eventually start. Every other cycle works fine. Once the spin cycle starts, it will run throughout THAT spin cycle, but I have to help it start on the next spin cycle. This is irriatating since I can never leave my house once I start a load. Any thoughts? Thanks in Advance
The plastic agitator is secure to the center steel shaft, but the transmission or gearbox is not...
(More)
The plastic agitator is secure to the center steel shaft, but the transmission or gearbox is not producing any activity
