Question about HP OfficeJet 4215 All-In-One InkJet Printer
HP Officejet 4215 All-In-One Error: Remove/Check Left Cartridge?
I cannot fix this error message that has me stuck. I found some info on the net that I tried (clear taping up certain metal spots on the cartridge plates itself that supposedly works but didn't for me). The odd thing is the LEFT cartridge is the COLOR tank that I've "NEVER" used to print ANYTHING in color since I've had this printer (since 2006). This message has left the printer useless since it won't print, fax, scan or copy at all! Should I simply just buy a new color cartridge or just take it in for tech service?
  • Anonymous Mar 25, 2008
    I have remove and check left cartridge error. Can't find the problem
  • Melonie1977 Mar 05, 2009
    I have the same problem, I have removed and checked it, I have cleaned all contact points with alcohol and a coffee filter and still nothing! HELP
Apparently HP meant left cartridge when looking from the back of the printer. I replaced that one (B/W), problem went away. Sort of dumb...
Posted on Jun 24, 2010
  • 233 Answers
Even if you don't use the color cart it still uses it sometimes or/and it has gone bad after so long the printer requires it even if you don't use it.
try a new cart. you didn't say what the error is,
Posted on Jan 05, 2008
    New Friend:
We have same problem,tried new cartridge,tried resetting it tried the tape thing no luck.i hate hp
Posted on Sep 01, 2013
I need Help fixing my HP Officejet 4215 All in One it keeps saying Cartridge Error and wont let me print anything.
Try reinstalling the printer drivers and software and plug connecting to the pc too
If problem still persist
There may be a problem in the cartridges holder
Then you have to connect with the customer care of the printer.
Or have to buy new printer easily and cheap at ebay
Aug 29, 2015 | HP OfficeJet 4215 All-In-One InkJet...
HP 4215 "cartridge Error"
Remove the color cartridge and close the lid
If the error comes up again, remove the black cartridge and insert the color cartridge.
When the error disappears the faulting cartridge will be the one that has been removed
from the printer.
The cartridge will need to be replaced
Feb 15, 2011 | HP Officejet 5610 All-In-One InkJet...
Cartridge error
Hi,i once had the same problem with my machine,I was able to fix the error message of check cartridge, using cotton swab with rubbing alcohal, clean the 2 cartridge holders including the back part. chance are you will see black all over your q tip. continue to clean everthing. then buy 2 new cartrdiges that are not refills and it should work. the only thing is since the cartridge has expiration dates this cause a problem for the printer for some strange reason. my machine is working fine now
Thanks and good luck
Jun 08, 2010 | HP OfficeJet 4215 All-In-One InkJet...
4215 cartridge error
Hi there ok Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 09, 2010 | HP OfficeJet 4215 All-In-One InkJet...
Hp officejet 4215 all-in-one "remove and check left cartridge"
^_^
uninstall all existing printer driver on your computer..maybe you have two or three driver installed..
an then..
install compatible driver to it..
May 12, 2009 | HP OfficeJet 4215 All-In-One InkJet...
Hp officejet 4215 all-in-one printer screen says remove and check
try to shut it off and up it again...
other solution..
clean the tab circuit of the printer where the cartridge is installed...and also clean the tab circuit of the cartrdge...
warning before opening the printer please shut it off...
to avoid injuries,,,,,^_^
HP Officejet 5510 error "Remove & check color cartridge
Re: OfficeJet 6310 Tricolor (93/95) Cartridge Stops Working After Replacing B/W (92) CartridgeOptions
04-26-201210:27 PM
1. Remove all cartridges and turn off printer
2. Unplug printer and wait one minute
3. hold down # and 9 while plugging power cord back in.
4. Wait a few seconds, then press the power button.
5. Display should read "Full Null Reset"
6 Only install color cartridge. Close cover
7. Wait for machine to ask for black cartridge, then open cover and install black cartridge.
8. Close cover
9. Alignment page should be printed automatically.
Mar 16, 2009 | HP Officejet 6310 All-In-One InkJet...
HP office jet 4215 all-in-one printer. Getting a cartridge error
Are you sure you installed the ink cartridges correctly? They should snap in and then you should be able to do a Printer Test/Align cartridges function.
Which error message is it putting out?
Mar 12, 2009 | HP Officejet 5610 All-In-One InkJet...
Cartridge error
cartridge error 4255 all in one hp officejet how can this be fixed ?
Jun 15, 2008 | HP OfficeJet 4255 All-In-One InkJet...
HP OfficeJet 4215 All-In-One InkJet Printer Logo
1,311 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
