My phone want ring with incoming calls about 1/2 the time. I have full bars and it's set to LOUD ring.
Normally this happens after the phone hasn't been in use for a while or after I've been access apps or my pictures. I can normally get it to work after I go thru all of the settings and ok everything. I'm not even sure what I'm okaying that makes it work but that seems to do the trick. Then it works for a while until I go back in access apps or pics or some other application.
Do you think the phone is getting confused as to what its supposed to be doing (ie phone, camera, or mp3 player)???? I didn't purchase the memory card or the audio pkg. Do you think that has something to do with it ???
Have you installed any other applications on you phone which might be using up the memory when u get a incoming call. Check the memory status when this happens in the phone main menu. Top left main screen>botton left menu>memory status. If this is the issue that get a memory card transfer all your songs to the sd card, if you like listening to the music use the S9 BT headset, it has a good performance dleivers gr8 sound. Cheers
Was this solution helpful? Show your Appreciation by rating it:
