there should be a vga output its normaly black or blue on the side or back of your laptop its the cable that a monitor would plug into you can plug that into a vga input on most newer tv's or your laptop may have an S VIDEO out put which looks like a mouse or keyboard port and is usually yellow check your owners manual to see if you have these or look it up online then you just have to buy the proper cable to connect it I use an S video cable that converts to Audio video cables and plug it into my tv that way so im sure you can find a way to do it you may need some type of adapter once you know what your tv and what your laptop has for connections the only real reason i would recomend doing it is for watching movies from the laptop because the quality of the picture sucks for web surfing but is awesome for video in my experiances
Was this helpful?
Yes
No
2 people thought this was helpful
Asker's Testimonial
Thanks for the quick response davepcrepair.I have a vga output and i will get the appropriate adapter.
Thanks again
" - weasel65
first check if you have a video output (yellow plug-in socket beside or back of the laptop) installed into your laptop.....their is a cabe that is one side is an earphone pin connector and the other side is the DVD video and audio output connector pin....buy this cable @ any electrnic store and use it to view display your screen resolution to your Television.....
dependant on the outputs at the sides/Rear of the laptop.
You may also have to configure it, Through start/Control Panel/ Display/ settings. Enabling a second screen With required resolution et,c.
Then usually activated by pessing the Fn and F key with 2 monitor pics on or Similar.
Check the manufacturers website, For a User Manual Guide.
Mike @ Compurepair.
Was this helpful?
Yes
No
Popular Solutions for Toshiba Satellite Pro L300 PC
I have Toshiba A355-S69253. Laptop got frozen when I tried to log in to Internet. Then all of suden,...
(More)
I have Toshiba A355-S69253. Laptop got frozen when I tried to log in to Internet. Then all of suden, the display went off. It is blank, but the power is on.
downloaded apple safai and itunes, everything slowed down went to shut down to restart and laptop in...
(More)
downloaded apple safai and itunes, everything slowed down went to shut down to restart and laptop in continual logging off mode
