No solenoid. Try opening up the heater, check the inlet and outlet with a toothpick or something like that. be sure to not lose any of the tiny rubber o rings. The heater always gets clogged with mineral deposit. The thing that prevents these from distributing the water most often however, is the air tube on the pump. it is fed from the motor fan. If you are running your machine, and you can hear a distinct sucking sound, like there is an air leak, then your air tube is not installed properly at the motor opening. Also, you must have a taught belt on your pump pulley. The pump is run by the belt system off the brush roller.Hope this helps. Let me know! Thanks, Rene (the Vacuum Doctor)
Thanks Rene,
Took cover off the heater and removed hose and tried to blow through the heater. No air through...took hoses off and with a small wire jiggled in the outlet while blowing and crystals broke loose. Works fine now. Thanks again.
Larry
have the lower unit apart and can't get the water selector to line up so that i can put it back...
(More)
have the lower unit apart and can't get the water selector to line up so that i can put it back together again.
My Bissell proheat shampooer releases the shampoo on the carpet but when I go to ****-up the dirty...
(More)
My Bissell proheat shampooer releases the shampoo on the carpet but when I go to ****-up the dirty water into the plastic bucket to empty it there is no dirty water. Please advise or refer a repair place close to Pinellas Park, FL 33782. I have used this machine for about 2 years.
I have a Bissell Prohet Clearview Plus. The foot pedal is broken and accessory holder is broken. Can...
(More)
I have a Bissell Prohet Clearview Plus. The foot pedal is broken and accessory holder is broken. Can I get replacement parts for these? Can these be repaired and how much? Thanks.
