Question about Lexmark X75 All-In-One InkJet Printer
Printer won't print.
I have no errors and according to my computer everything is in working order
  • debvig Jan 05, 2008
    My lexmark won't print
  • 2,427 Answers
Click on start / printers and faxes and verify that your printer says on line, right click on it and make sure it says use printer online if it says other wise change it to use printer on line
if that fails unjack your printer from the current usb port and connect it to another. :)
cheers
Posted on Jan 05, 2008
6ya staff
SOURCE:
My office jet G85 won't print. No error messages appear,it has a new color cartridge,it copies, but won't print from my computer.
If it copies ok, then the issue is either the way it is cabled to computer or the print driver software settings on pc.... How is it connected via USB? Check port and correct driver is in windows/control panel/printers. Reinstall.
Nov 30, 2011 | HP OfficeJet G85 All-In-One InkJet Printer
Kindly, read the previous posts. I have taken some time to compose them accurately and carefully. I cannot think of any more information to submit to resolve my problem. I can't print. According to...
If everything at the printer looks fine (test prints, and no errors on the display) I would de-install and reinstall the software. The DE-install is important, DO NOT just reinstall over the top of the current installation. Also I would reboot after I removed the software and BEFORE I reinstall it. It might be overkill but it won't hurt to be through.
Sep 22, 2011 | Xerox Phaser 740 Plus Laser Printer
The black ink on my Brother DCP-130C won't print and it's a brand new ink cartridge. I thought it was a defected cartridge so I bought another one, same thing. The other 3 colours print ok though....
I have the same problem. Everything on the printer is working just fine. It'll do a test page just fine, so everything's working right. The %$^ thing just won't print. It makes noise like it's printing when you give it a print job, but it spits out blank pages.
Sep 08, 2011 | Brother DCP-130C InkJet Printer
"Communication Not Available" message is displayed
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Unplug and re-plug the printer into the power source to reset it.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list again, then try to print again.
You may also try to update your printer driver by visiting the Lexmark website at . Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 16, 2011 | Lexmark X2670 All-In-One Printer
Hp psc 1210xi all in one printer says refilled cartridge is defective. HP says printer remembers cartridge serial number, counts number of prints executed & after certain number of prints, won't...
Well, if the electronic circuit on the cartridge has blown, you have no other alternative then to buy a new cartridge. You can remove the cartridge and gently wipe the cartridge contacts. Turn off your printer, wait for a few min, then turn it back on. Put the cartridge back.
If that doesn't work,
  1. Open the cartridge access door.
  2. Remove either cartridge (not both).
  3. Close the cartridge access door.
    • If the computer message is Print Cartridge Error , then the print cartridge that is still in the printer is the problem cartridge.
    • If the computer message is NOT Print Cartridge Error (instead, it says that the cartridge you have removed is ...Either missing, not detected, or incorrectly installed ), then the cartridge you have removed is the problem cartridge.
There is a cmos battery in the printer, and, yes, when you remove it, the printer forgets everything (serial number, number of copies, etc). I have found a clip, but it says it only works for some HP printers. You can try that, but I am not sure that will help solve your problem.
Jan 28, 2010 | HP PSC 1210 All-In-One InkJet Printer
Print cartridge error, all lights flashing
there isn't any guaranty the printer will work after you changed the ink cartridge. the only thing I suggest is the change the cartridges.
turn off, and disconnect the printer from the computer.
restart the computer, turn on the printer and connect the printer to the computer. if all things are in order, the printer should start-up and ready to go.
good luck
Mar 24, 2009 | HP Officejet 5610 All-In-One InkJet...
Hi there my printer is not working, everything is connected
Does your computer recognize the printer? Did you select the right printer under the printer Name? What error messages do you get if any? Was the printer working before?
Basically, I need more info in order to better help you.
Dec 10, 2008 | HP LaserJet 1320 Printer
HP LaserJet 1018 & DP-G310
Does your network have a dedicated computer server and the printer is attached to this server or is the printer attached to a dedicated print server device?
OR
Does a computer on your network shares its printer with other computers on your network?
There is insufficient information on how you configured your printer setup for me to give you a proper answer to your problem.
Jun 10, 2008 | D-Link Air Plus DP-G310 (dpg-310) Print...
Lexmark X75 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
