Question about Biostar P4M800 Pro-M7 Socket 775 mATX MB w/Video Audio (ETKMBB-P4M8P-M7) Motherboard
Over heating processor
I bought a mach speed p4m800pro-m7 mother board also a celeron 3.46 processor. just a simple upgrade. the problem im having is the processor is heating up around 80 to 85 C. i boot up it will run 3 to 5 minutes then lock up. i have 2 case fans one pulling in in the front and the other pushing out in the rear. also the standard heat sink with fan on the processor. i have the side cover off with a 4" fan also blowing on the processor. someone suggested i get the pc off the floor to help with cooling. no matter what i try i cant get it cool enough to run can u help.
  • 27 Answers
  • First, move it away from the wall, off the carpet floor, and try closing the air vent that hot air travels through into your room (not too much, don't freeze youself to death).
  • Then try taking canned air and blowing all the dust out of your computer. Only spray in short bursts or else liquid will come out and permenatly damage your computer.
  • Get a more expensive (and bigger is usually better)heatsink maybe around $25+,
  • and if that doesn't work go to BIOS (it should tell you how to get to BIOS everytime your computer boots) and disable any new technologies, like hyperthreading.
You must keep the case on so that the air actually flows like a current. opening the side case makes the case fans useless. keep the large fan blowing on it though.
Follow everthing in order and test it by playing games for an hour and taking the temp. 70 degrees celcius is actually pretty cool, so you can have it around 75-80.
A lot of things could explain this problem too, like damage to the motherboard, faulty BIOS chip, hardware incompatability, bad memory, etc. all coming back to your motherboard. If you find that its not the heat then you need to get it checked out by a computer shop.
Posted on Jan 05, 2008
Sir/Maam, i have intel celeron D331 processor 775 lga socket . i want to upgrade Motherboard, can i use ecs G31T-M7 (775 lga socket)? if not, what board brand/model do i have to use?i want latest ddr2...
As long as the socket is the right type for the processor, you can use the motherboard. Just be aware that changing the motherboard won't make the processor any faster, so you might not see a big performance improvement unless you upgrade the processor along with the motherboard and RAM. Many vendors offer package pricing on motherboard/CPU combinations, so you may want to look into that.
Jun 26, 2011 | Intel Computers & Internet
Will the asus 1000hd support the intel T5250 dual core processor because the 353 celeron is ****
Usually the net books are what one would called Wireless internet laptops not noted for power.
The net books users don't need a lot of power to view and user the internet.
the processor is about the speed of a Dell laptop was 7 or 8 years ago a 1.6 GB
which is just fast enough but the CPU is hard soldered to the mother board and not upgradable. A celeron processor is about all your gonna get here.
Oct 07, 2010 | ASUS Eee PC 1000HD Netbook
CPU Support
Go to your motherboard website and check it's CPU specificaions
May 25, 2010 | EliteGroup 661GX-M Motherboard
Is it possible to upgrade to a faster processor on a hpn pavallion dv1000
here is a list of processors supported on that machine
Intel Pentium M 745 (1.8-GHz) with 400-MHz front
side bus (FSB)
Intel Pentium M 735 (1.7-GHz) with 400-MHz FSB
Intel Pentium M 725 (1.6-GHz) with 400-MHz FSB
Intel Pentium M 710 TJ85 (1.4-GHz) with 400-MHz FSB;
operates at a lower temperature than other processors
Intel Celeron M 340 (1.5-GHz) with 400-MHz FSB
Intel Celeron M 330 (1.4-GHz) with 400-MHz FSB
Mar 15, 2010 | HP Pavilion dv1000 Notebook
I have an ECS P4M800-M7 motherboard using Celeron D 2.66Ghz processor.What compatible processor can i use for upgrading.
Intel Pentium 4, Celeron D and Pentium D processor FSB 800/533 MHz Support Hyper-Threading Technology Also says Dual Core support See here for information:-
Jun 13, 2009 | EliteGroup Intel Pentium 4 Processor...
I have p4 3.06 ghz processor on mother board it is written P5P800-vm/s i require VGA and sound drivers(realtek ac97 sound driver} i have i P5P800 VM motherboard and i was wondering if i can upgrade it's...
NO. you cannot install DUO to *********** board. the DUO is pinless and the P4 3.06 is pin type if you want to upgrade your PC you have to replace the mother board too.
May 18, 2009 | ASUS P5P800-VM Motherboard
I have an intel celeron 1.79 GHZ on my dimension 2350,what is the better processor for upgrade? and is there something else that i should change inside for the new processor?
you said that you want to upgrade ur 1.79ghz celeron cpu.
to upgrade a cpu just check that the packaging of the new cpu matches with the motherboard.
and also check that the motherboard supports the new cpu that you are installing. check this in the manufactures site.
Apr 14, 2009 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
Upgrade intel celeron processor 798 MHz
it is better to use intel core2 dueo or intel quad core processor
Jan 12, 2009 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
Upgrading Processor
You can not put a dual core processor in there because the board will not support it. However, you are able to place any socket 478 pentium 4 processor in there. Let me know if this helps.
Aug 01, 2007 | Asrock P4I45GV R5 Motherboard
Biostar P4M800 Pro-M7 Socket 775 mATX MB w/Video Audio (ETKMBB-P4M8P-M7) Motherboard Logo
152 people viewed this question
Top Biostar Computers & Internet Experts
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
