Home | Vizio | L32 32 in. HDTV LCD Television | 32'' Vizio LCD no pic...
Vizio L32 32 in. HDTV LCD Television
Problem for Vizio L32 32 in. HDTV LCD Television
32'' Vizio LCD no picture or sound
By sallyfl1 on Nov 05, 2009
I have a 32'' Vizio LCD, i heard a pop sound and now i have no picture and no sound. The tv will power up but you have to unplug to turn it off. what could this be, a fuse?
Best Solution
posted on Nov 05, 2009
Very Helpful)
circuitworld
Rank: Guru  Televisions & Videos  Expert
Rating: 88%, 68 votes
Your filter capacitors have popped due to diodes shorting, P-channel FETs shorting from gate-to-drain. Pull-up resistors have changed value and as a result your capacitors have peaked (popped)....so now the tv is in protection mode to prevent further damage to your tv. Take it to your local shop for servicing, or take it back if its under warranty......
Comments:
Nov 08, 2009
- The tv has No picture and No sound after popping noise right?...........
The popping noise your heard is either some kind of inductance arcing or a popped capacitor. The tv has low-voltage closed DC power (green light) but theres a DC high voltage shut down. This means the power supply is not feeding high DC voltage to the other circuits. The main board (Processor Interface) is not getting its high-voltage (14-18v) DC to Up-Start its other system controls. Critical Waveforms are not being generated. So the tv's protection circuits are in affect to prevent a fire from starting.
Your power supply needs to be serviced first.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Nov 06, 2009
Not Rated)
budmrtn
Rating: 87%, 143 votes
If the TV does power up then at least the 5v standby circuit is working, but the problem can be in the main controller board since you cannot turn it off (it is not sending the signal to the main power supply to turn off)
Was this helpful?
Yes
No
Popular Solutions for Vizio L32 32 in. HDTV LCD
Questions and Unsolved Problems for Vizio L32 32 in. HDTV LCD
Do you recommend Vizio L32 32 in. HDTV LCD Television?
Answer
Answer
my vizio 32 tv remote stopped working my direct tv remote used to work the tv but now neither of... (More)
Answer
trying to register my new tv thru the provided web site, but it isn't the correct one.
Answer
I'm fairly sure, unless I dreamed it up, that I saw an article in the Daily Telegraph a short while... (More)
Answer
no picture lost insstantly displlay says no signal
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Vizio L32 32 in. HDTV LCD...:
Top Flat Panel Television Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Flat Panel Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
