Question about Samsung SyncMaster 245BW Monitor
Default settings on service menu
Could someone out there please tell me what the default setting are on the service menu for this monitor.This is the menu that includes the panel info and version of the monitor.thanks..
How do you acess the service menu?
Posted on May 01, 2008
6ya staff
SOURCE:
How can I set my DELL E2210Hc monitor to reset to factory default
To help you reset default settings of Dell monitor, please find the instructions step-by-step given below:
- Press the 'Menu' button on the monitor panel.
- Press 'Plus(+) or Minus(-)' button to move to 'Menu Settings'.
- Again press the 'Menu' button.
- Press 'Plus(+) or Minus(-)' button to move to 'Factory Reset'.
- Again press the 'Menu' button 'Twice to Reset'.
- Press 'Plus(+) or Minus(-)' button to move to 'Exit Menu'.
GuruAid.com
Jun 05, 2016 | Dell Computers & Internet
Why my monitor screens is color green
Your RGB settings has most likely been altered, resulting in some problems. Check your settings menu on the monitor itself and reset the settings to default. If that is not the problem, it's probably the computer's settings that has caused this change. You will need to go to the computers monitor settings and reset that to default to get back to normal colours.
Nov 04, 2012 | Samsung SyncMaster 915N 19" Flat Panel LCD...
Screen size
Hello. If you can try removing the back cover of your monitor, then you can reset it to default setting. Unscrew the stand of your monitor. Use a plastic flat screw driver to detach the back cover and expose the main board of your monitor. On the board, there should be a small reset button. Plug your monitor and turn it on. Press the small button on the main board to reset it to default setting.
Jun 13, 2010 | Gateway FPD1950
DP 37819 Sanyo LCD 37' service menu defaults
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 15, 2017 | Sanyo Televison & Video
Warning "not optimum settings"
Press F8 as the computer boots up and the Windows Advance Options Menu will be displayed. Then select Safe Mode to boot up the computer.
When Windows finishes booting up, then open Control Panel - select Display - Settings, then change the screen resolution to a lower setting.
Apply and shut down and reboot computer.
Dec 19, 2009 | Samsung SyncMaster 912N 19" Flat Panel LCD...
My computer display was moved?!?
The vs19 is an LCD. That meand Liquid Crystal Display and the monitor is very thin and very light, unlike a CRT which is big, heavy and bulky. You need to find the icon within the menu to reset the monitor to factory default settings. See if that helps. Click this link to see how to adjust it to factory default.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00307479&lc=en&dlc=en&cc=us&lang=en&product=447387
Aug 19, 2009 | Computers & Internet
I need to know how to reset my monitor to factory defaults
Factory Setting & EEPROM Initialization Method
Factory Setting Method
- Connect the signal cable and power cable to the LCD monitor.
- Press Power switch with pressed MENU key.(Menu key + Power key).
- Then, a User can change the factory setting value in OSD menu.
- Save changed value and Turn off the power s/w.
- Turn on the power, adjust the screen.
Apr 15, 2009 | Hyundai ImageQuest 19 L19T LCD TFT 19" LCD...
Ricoh IS200e Web interface password
default login: scanner
default password: password
Jul 17, 2008 | Office Equipment & Supplies
Monitor displays everything upside down
There are two options:
Stand on your head, or..
Someone may have messed with the monitor settings.
Right click anywhere on your desktop, then choose "properties".
Then click "settings"
Then click "advanced"
If you're using any 3rd party video card (asus, nvidia, ati, etc), you will see an extra menu like this:
Jan 19, 2008 | E-Machines eMachines W2686 PC Desktop
Samsung SyncMaster 245BW Monitor Logo
902 people viewed this question
Top Samsung Computers & Internet Experts
Ekse
asber
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
