Question about Bissell 3594 CleanView PowerTrak Bagless Upright Vacuum
Bissell Powerforce Bagless Vacuum
I got this vacuum from a friend on mine. It will suck up the dirt but wont go into the container. When I detach the hose to get into the corner it dont have air! I have taken it apart 5 times and same affect. I need help!
  • 1,673 Answers
Re: Bissell Powerforce Bagless Vacuum
Either your hose is plugged, or the inlet by the brush roll is plugged. Another problem that can cause this is the the filters are clogged or may just need to be replaced. Most of these has a filter in the dust catch bucket, and also above the bucket. Make sure all filters are clean.
Posted on Jan 05, 2008
0 characters
3 Points
We have this vacuum and its not sucking enough. its sucking at about 50% capacity. we vacuumed an entire room and when we opened it up, there was nothing in the dirt holder. we have cleaned all filters and...
A common probem with vacuums that are equipped with an attachment switch is the switch isn't all the way in it's normal position. Our Bissell has a yellow dial that switches from normal to attachment mode and will only work at 1/2 its power if the switch isn't in vacuum mode.
Dec 13, 2009 | Bissell 6594 PowerForce Bagless Upright...
No dirt is collecting in chamber and doesnt seem to be picking up
the hose is clogged. try sucking the dirt out with another vacuum (backward) If this doesnt work, you will have to disconnedt one or the other or both ends of the hose to remove the clog. this is a simple process.
thanks for your interest in
Not sucking up dirt off floor any longer
Chances are there is some blockage in the pathway from the floor to the bagless colllector. Use a flash light to look in the tube and straighten out a wire coat hanger to probe the areas you can not see.
Finally if your vacuum has a beater bar/brush that spins against the floor check to see that it is spinning. If it is not, that indicates that the belt which drives the brush is broken.
good luck.
May 27, 2009 | Bissell 6594 PowerForce Bagless Upright...
Bissell cleanview bagless - dirt doesn't end up in container
i have a bissell power brush shampoo cleaner, it will not release the soap. what is the problem
Feb 20, 2009 | Bissell Cleanview Powertrak 35933 Bagless...
Bissell bagless
I had the same problem, called Bissell over 10 times! They send me 3 plastic inserts for the dirt chamber, not the problem. I solved it by throwing the Bissell away and buying a Eureka bagged vacuum, no more problems.
Oct 21, 2008 | Bissell 6594 PowerForce Bagless Upright...
Bissell PowerForce Bagless Vacuum (6582)
You just have to twist hard the first time for some reason. If you hold the container with your right hand you actually have to twist the bottom half CLOCKWISE when viewed from above.
Oct 11, 2008 | Bissell 6594 PowerForce Bagless Upright...
Bissell powerforce bagless upright vacuum 6594-w
Be sure when you put the dirtant dust container in place that it is in properly. I have had this and believe it or not this container has enough room to fit without it seating properly. Take the dust container out and reseat it making sure the bottom is secure and then turn the lock lever in place. Try it again. What happens is you get an air gap which allows some air to flow but the vacum does not function properly.
Aug 26, 2007 | Bissell 6594 PowerForce Bagless Upright...
My Bissel powerforce vacume filters
Remove the lower half of the dirt bowl by turning counterclockwise. Turn the filter counterclockwise, remove the foam filter and clean both with soap and water.
Jun 16, 2007 | Bissell 6594 PowerForce Bagless Upright...
Bissell 3594 CleanView PowerTrak Bagless Upright Vacuum Logo
118 people viewed this question
Top Bissell Vacuums Experts
Roger Potts
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
