Question about Soleus KFR-18 Air Conditioner
Air conditioner serviceman says fan needs replacing and will cost $900-$1000 seems expensive for a 25 year old air-con. Do you have a service manual and a rough idea what a new fan would cost as Im a handy guy. Gazza from australia.
    Scholar:
  • 54 Answers
I agree, here in mid south US i would typically charge about a 120$ labor and around 200$ for a typical blower and cleaning and service materials. 900$ seems high i would get a second opinion, theres always the possibility that there is some additional cost that we are not aware of, service difficulty such as unit location, travel time and so on.
Posted on Mar 11, 2008
Go to any BOC Gases outlet and view their range of aircon fans. Depending on model $100 to $200. Fans are not an expensive item.
Allow an hour or two of labour (in case there are problems)
Posted on Jan 05, 2008
Air conditional water drip
That happened to us. It was a broken pump, pump was up in attic. attached to our inside air-con unit. We had it fitted on an inside wall of the house, and so a pump must be installed to take away the condensed water to the outside of the house. Hindsight being 20/20 I would never buy one that needed a pump to get the condensed water out of the house. We would have put it an outside wall where the water goes straight outside, no pump needed. Our First pump lasted just over 2 years so warranty was expired. Cost us over NZ$500 to have new pump installed. Never again. Only attach your unit to an outside wall, even it looks prettier on the wall where it would need a pump. Bottom line:- Don't touch a pump. Pump was cheap but labor cost for serviceman astronomical! Bet of luck.
Apr 20, 2014 | Sanyo Split System Air Conditioner
Does the vw polo 1.6 Comfortline Air-conditioner need a fuse
Not sure whether the fan comes on automatically with air con or not... but if you manually turn the fan on, the vented air should be cold. If not, your air-con system sounds like it needs re-charging. This is not expensive and most decent service centres have the facility. Hope that helps.
Oct 10, 2012 | Volkswagen Polo Cars & Trucks
I have an old (25 yrs or so) through the wall Whirlpool ac. I plugged it in and it runs and cools but it is noisy. Sounds like the fan is hitting or something. When I switched from Hi cool to Low cool...
A through the wall AC unit that has lasted 25 years or so? That's amazing and unheard of !!!
iI it's tripping a circuit breaker, there's an electrical problem with one of the circuits, within the unit and that can be dangerous. Certainly repairing it is an option. But, at 25 years old, I doubt that there are many parts for that model left in existence. Not to mention that the cost of troubleshooting it, parts and labor may cost almost as much or more, as a new Energy Efficient unit would cost.
You have to admit, you got your monies worth out of it over the past 25 years. So, if it were me making the decision, I'd opt for a new Energy Efficient model, with the same cooling capacity as your old one.
Hope this helped you. Please let me know. Thanks.
Jun 17, 2011 | Whirlpool ACC108PS Air Conditioner
It seems that the cooling part of the air conditioner is working but the fan is not turning on. is this a major expense to fix?
If it's just a loose wire or a fault ON/Off Switch, it isn't that expensive to replace. However, finding the right part, may take some time. If the fan motor is shot, then that's a bit more expensive to repair. And, again finding the matching motor will take some time. If the unit is over 5 years old and it's a window or thru-wall AC unit, You may want to consider replacing it, with an upgraded model, that's energy star rated and has a good warranty,. With the option of purchasing an extended warranty. In the end, that can be money well spent. I almost always you Square Trade for extended warranty service. They run 25 to 30% less, than what the store offers and is just as good or better. If you want to check them out, you can find them online or call 1-877-WARRANTY
Jun 10, 2011 | Frigidaire Heating & Cooling
Brand new (3 weeks old) 14K btu Frigidaire blows cold on and off. Serviceman came out (when it was working) and found nothing wrong. Are they just junk or what?
No sometimes the problem is intermint if it just three weeks old take it back for a new one. Dont wast your time for a service call, its cheaper ti repace.
Jul 17, 2010 | Frigidaire FAH146R2T 14,000 BTU...
Conia 3 HP, 5 yr old air con/ condensation from wall unit
NOW, THE EVAPORATOR COILS NEEDS CLEANNING OR THE DRAIN LINE PLUGGED,OR JUST CLEAN THE FILTER.
Nov 30, 2009 | Heating & Cooling
My unit is 9 years old Ruud RCGA-60AIGH24B seems
It's possible that there is gas leak causing part of the coil to freeze. The cost will depend where the leak is.
Jul 12, 2009 | Heating & Cooling
My RV rooftop air conditioner fan has seized up
Whether to replace the entire unit or repair it is a tough decision. If the unit is not very old and was working fine before the fan motor froze up, then I do not think that it is necessary for the entire unit to be replaced. With a new unit of course comes the new warranty.
It is not difficult at all to replace the upper unit of the air conditioner. What you have to look for and make sure of is that the ceiling pack or Air Distribution Box (inside unit of AC) that you currently have is compatible with the new Upper Units. Get the part number off of the inner unit and make sure that it is compatible with the part number of the new upper.
Again, it is much less expensive to replace the fan motor than the entire unit (especially Dometic). You could replace the fan motor and get another 10 years out of the AC or, you could replace it and only get 1 year out of it. That is your call.
Just a word of precaution. Dometic Air Conditioners are very hard to find right now due to an industrial accident that occurred at the AC plant. Most distributors and service centers are 6 to 8 weeks out on getting a Dometic AC in stock. That is something else to think about.
Hope this helps,
Jeff
Jul 05, 2009 | Dometic Rooftop RV Air Conditioner
Danby DAC5020 Air Conditioner fan works but not compressor
It could be as simple as being low on refrigerant. Depends on how expensive the unit is if its worth recharging and how big the unit is. Some small units will need to have a recharge point fitted which cost more of course.
Jul 02, 2009 | Danby DAC5020 Air Conditioner
Soleus KFR-18 Air Conditioner Logo
93 people viewed this question
Top Soleus Heating & Cooling Experts
Michael Galve
Michael Galve
Dennis Boxerman
Craig Butler
Craig Butler
Are you a Soleus Heating and Cooling Expert? Answer questions, earn points and help others
