Question about Lexmark X1150 All-In-One InkJet Printer
Printing from computer
My lexmark x1100 will print a test page with all the colors and black ink but won't print any thing from the internet in any colors or black ink at all I just get a ablank page
  • 233 Answers
Check the cable connections and re-install the driver/software
go to lexmark website and get the latest driver for your operation system.
Also when you print, make sure you are printing to this printer
print from word-pad or any other program OTHER than internet.
Posted on Jan 05, 2008
Why won't my Lexmark 5600- 6600 Series Printer print in color?
It could be the print setting on the application where you're printing from. Before you send your print job and hit "Print" button on your computer, check in the Printing Preferences and make sure it is not set to print "Using black ink only.".
Mar 06, 2012 | Lexmark Office Equipment & Supplies
Printer shows it is printing and it just pulls paper through and nothing has printed. I have changed ink and still won't work. I've cleaned print head. It will only print black and not colored on...
A firmware update for your model addresses a number of issues including print quality issues. Please visit the Lexmark website to download and install the Lexmark S300 Series Firmware Update.
Should the problem persists, please contact Lexmark Technical Support Center for additional assistance. Thanks.
Oct 17, 2011 | Lexmark S305 IMPACT LEXS All-In-One...
Lexmark Series X1150 My printer does not recognize the color print cartridge and only prints in Black even though the color cartridge is new. First time this has ever happened. I've had the printer...
Make sure you are inserting the correct color cartridge versions for the Lexmark X1150 (either #26 or #27).
Try to clean the cartridge nozzles. On your computer, open the Lexmark Solution Center, click Start > Programs > Lexmark X1100 Series > Lexmark X1100 Series Solution Center. From the Maintenance tab, click Clean to fix horizontal streaks. Your printer will then print a page that will help clean the nozzles from possible dirt and clogs.
If that doesn't help, try to insert a different known working cartridge (e.g. your old cartridge or another new cartridge). It could be a faulty cartridge issue.
Sep 01, 2011 | Lexmark X1150 All-In-One InkJet Printer
I am out of black ink and need to finish a project. How do I switch to color
You dont both inks are used at the same time so if you are getting nothing try running a test page that has color on it to make sure that you have color ink . if it prints in color that way that tells you that there is no "switch" to use color to print black text you will need to replace the black ink cartridge
Mar 28, 2011 | Lexmark International Lexmark 3300 Series
My lexmark 1150 won't print and I've lost cd and don't have the manual book. Would it have any thing to do with because I put in ink cartridges 17 and 27 and it requires 16 and 26 ink cartridges.
It works with both 16 and 17 for Black and 26 and 27 for Color.
Go to the Panel from Lexmark X1100 series- Series Solution Center and select the new type of cartridges. Allign the cartridges, make an excel test with 4 colors(cyan, magenta, yellow, black) and it should work
If you need further assistance, do not forget to post and don't forget to rate.
Thank you
Feb 27, 2010 | Lexmark X1150 All-In-One InkJet Printer
Color ink want print after installing new cartridge
have you installed the cartridge correctly??? make sure you did
try to print a few pages, to get the ink going.
try test pages, try the aligning procedures as well.
Mar 26, 2009 | Lexmark Z515M InkJet Printer
Printing not complete
you may check your ink cartridge
1) the cartridge some color almost empty, need to change a new one or refill the match color ink. test it and go next if not fixed
2) long time less using cause some color ink chanel(holes) dryer, you may take out the color ink cartridge and put it's surface of bottom (just touch ) in the clean water 1 Hr, then set back and test it. still not fixed, you also need to do same thing if your print head is separated from your ink cartridge
Feb 06, 2009 | Lexmark X75 All-In-One InkJet Printer
Lexmark 2500 printer won't print after replacing black cartridge
Unfortunately the printer wont print unless there is ink in both cartridges
Jan 01, 2009 | Lexmark All-in-One Printer with PictBridge
I have a Lexmark x1100 Series printer and cannot print anything now. This printer has been working but it stopped printing. Do not have the CD.
Need more info. Any error messages? Did it just stop pumping ink on paper. Are you trying to print black text or color picture? If no error, your cartridges may be empty. If black text does not work, try color picture. Usually one cartridge goes empty and the other still has ink. If color pic prints replace black cartridge. If neither black or color prints at all, it may be a toasted printhead
If you need to reinstall the software, uninstall it, then go to lexmark.com and get new drivers from their site. RESTART COMPUTER! Reinstall from the downloaded file.
If all the above fail to make it work, it is hosed, shop for new printer.
Dec 09, 2008 | Lexmark Office Equipment & Supplies
Lexmark X1100 printer will not print black
I came up with a work around for printing black.
I changed the black cartridge with the color cartridge.
Then when I have a letter to print, I change change (or write) the letter text to yellow, red or blue.
Then I can print out a letter.
By printing the text as yellow, red or blue the cartridge will try to print with only 1 color, but will print out black.
If you do not use one of these primary printing colors the out put will be unusable.
I can not of course print out pictures.
Oct 04, 2008 | Office Equipment & Supplies
Lexmark X1150 All-In-One InkJet Printer Logo
70 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
