It says out of paper "p" when there are lots of paper. And sometime it gets caught does not get fed. It's short of being jammed. If I open and close the paper tray a few time, it does the trick. what might be the prob?
Comments:
Nov 06, 2009
- I think that did the trick!
I didn't have alcohol on me so I just used a wet paper towel.
Seems to be working so far.
Thank you!!
Pull out the paper feed tray and (using a flashlight to look into the machine) clean the halfmoon feed rollers with rubbing alcohol on a cotton ball. The rollers are on the right side at the top where the paper tray fits in. If alcohol doesn't do the trick, try naptha (lighter fluid), if no success...replace the feed tires....just a thought. Let me know please...Tim
PS...if it doesn't feed paper far enough, it thinks there is no paper or a jam.
After loading the auto feeder, Scan Menu asks me to select computer. I press OK. The banner reads...
(More)
After loading the auto feeder, Scan Menu asks me to select computer. I press OK. The banner reads (my name)+ macbook pro. I press OK. Screen reads Tiff To Preview and then Press START SCAN to begin. I press OK. Screen reads date and time and Original loaded. I press START SCAN. Screen reads Starting Scan...., but reverts to Original loaded. I have also tried scanning using the computer (MAC). At times it will run one page of four and then a screen pops up reading..Unknown Error. The hp will print and is showing connected. Thanks
How do I separate housing to get at bulb to replace it? I have the housing out of tv but can't...
(More)
How do I separate housing to get at bulb to replace it? I have the housing out of tv but can't figure out how to get to bulb itself
I have a Zinwell converter box and a Radio Shack antenna, both are properly hooked up to the ant...
(More)
I have a Zinwell converter box and a Radio Shack antenna, both are properly hooked up to the ant connection (only 1) in back of tv-vcr unit and the yellow and white connections in frt of unit are connected via a cable with r-y-w to converter box and y-w to frt of tv unit. At the advance record screen..channel 3 is showing in the selection box, if you insert a different channel it will not record that channel/program. Are there any converter companies that had the foresight to know that there are hundreds of tv-vcr combos still in use? I understand the mechanics for a stand alone vcr and I know how to manually record on the combo..but I want to be able to preset and for more than one channel and recording times. Thanx
