Question about Hoover V1 SteamVac SpinScrub Vacuum
Water leaking from bottom and hose not connected
I tried to clean my car upholstery and water didn't come out of attachment at first then came in dribbles meanwhile water was leaking from bottom. When I finished trying the bottom tank was dry, top was almost full and the hose on the bottom inside was not connected. How do I reconnect it?
  • Anonymous Mar 01, 2009
    hoover model F5905-900
    WATER WILL NOT COME OUT OF UPHOLSTRY CLEANER, THE RUG CLEANER WORKS FINE?
    President:
  • 1,673 Answers
The hose just pushes on. You will have to take the top cover off to rehook up the hoses. There are scres on the bottom, then where the dirty water tank sits, there tabs that you have to unhook, then the cover will come off. Note: the filter inside the ditry water tank, leave a gap at the top to the filter. If you push the filter all the way up, it won't spray or suck up.
Posted on Jan 05, 2008
How doI hook up furniture/stairs attachment
Hoover Steamvac Spinscrub - How To Attach Hose and ...
? 2:54
https://www.youtube.com/watch?v=XTgoEezUlRs
Mar 13, 2011 - Uploaded by Doug Weeks
... spin tool. Used for stairs and stains etc. hand held. ... Hoover Steamvac Spinscrub - How To Attach Hose and Spin Tool ...Every time I attach the upholstery and then turn the vacuum on, water begins to leak from the bottom.
Hoover SteamVac Connecting Hose & Tools F5915900 ...
? 1:41
https://www.youtube.com/watch?v=heAeez1YlFc
Nov 23, 2011 - Uploaded by HooverVideoGuides
How to properly connect the hose and tools ... Hoover VacuumVideo Guides ... I cant get the water to come out the water isnt coming out the spray part to scrub my furniture ... Get Best Price for Hoover SteamVac Carpet Cleaner here ... for the love of god when not using the hand tool where on the machine ...
Hoover SteamVac Connecting Hose & Tools F5912900 ...
? 1:41
https://www.youtube.com/watch?v=fPU9pXgNo98
How to properly connect the hose and tools ... Hoover SteamVac Connecting Hose & Tools F5912900 F5914900 F591... ... Hoover Vacuum Video Guides .... Hoover Steamvac Spinscrub - How ToAttach Hose and Spin Tool ...
Jan 09, 2016 | HOOVER COMPANY Steamvac Deluxe
Why is water pouring out the bottom when I try to use upholstery attachment?
On many hoover models the hose attaches to the vacuum and is held on by a clip on the hose assembly. There may be some damage to your hose or the place where it attaches to the machine. Inspect these areas trying to locate the point of the leak.
Feb 25, 2015 | Hoover SteamVac Carpet/Upholstery Deep...
Dirt devil ce6100
Hi there! Below are step-by-step instruction to assembling the hose to the cleaner so that you may use the attachments. I have also included a link to the instruction manual which gives instructions and illustrations as well. Hope this helps!
1. Put cleaner in its upright position. Connect the upholstery attachment to the trigger adaptor.
2. Remove the dirty water tank door.
3. Insert the hose adaptor into the dirty water tank.
4. Connect the base water supply connector into the fitting on the lower left side of handle facing cleaner. You are now ready to do above floor cleaning!
http://pim.ttifc.net/document/1549/
Jun 13, 2014 | Dirt Devil CE6100 Featherlite Upright...
Water leaks out under the unit when using the upholstery attachment?
You may wish to check and see if the leak is where the small water supply hose is plugged in to the cleaner base. That connecction supplies water from the product, to the spray end on the upholstery hose.
Sep 30, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
I have used my Steam Vac for carpeting, but until today, had never tried cleaning upholstery with the spin-scrub brush. I spent a miserable afternoon trying to control the spray, which seemed to go...
I can sympathize. My vac came with two handheld attachments. I have better luck with the handheld attachment that doesn't have the spin-scrub pads. To keep the water from going all over the place, you need to keep the part the you hold only about 1 inch from the surface of the upholstery; if you hold it higher it gets everywhere; if you hold it lower the spray doesn't spread out wide enough and it just makes big water droplets that roll down the upholstry.
If the vac isn't sucking up the water, it is likely you have it set up wrong. Take off the attachment; if you put your hand over the open end of the tube, do you feel suction? When you are using the handheld attachments there is a rectangular piece you remove (attached to the dirty water tank) and you stick the rectangular part from the hose in there. If you are getting suction but it's just not sucking up any water try these 1) maybe you aren't laying down enough water, spray it more heavily OR 2) you need to **** up the water right after you lay it down. Don't let it soak in for more than a few seconds.
good luck!
Aug 17, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Leaks when trying to use upholstry cleaner!
This is a common problem for these units, and is easily fixed.
Bad connection:
You may need to push harder on the coupling when attaching it to the machine
A leaky Valve
Manytimes the Valve you connect to can bust or crack where you cannot see it.
Remove the hood and inspect valve. (six screws on underside)
Leaky hose
The hoses that run to the Valve you connect to can come loose or crack.
Remove the hood and inspect hoses. (six screws on underside)
This machine may be leaking the whole time you use it, and you my just not be noticing.
If you are in a northern climate, freezing machines in garages or cars is the most common cause.
Jun 04, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover Steam Vac leaks like a sieve
I have the same problem with my hoover steam vac, different model but same problem. So I have had it for 2 years and never used the attachments because the thing leaked out the bottom when i tried. So today I tried to find a solution online and found nothing. So I started toying with the thing and found a solution for my model and I hope it will work for everyone else. I don't have a stair attachment so this goes for the upholstery cleaning attachment. I noticed right where my upholstery attachment connects to get soap, there is a second hole that is covered by a white rubber seal when the cover for the connection area is closed. I put a plastic bag, or anything to seal it, into this hole to make a tight seal. Tried the machine and worked like a champ. So Would be nice if hoover supplied a plug for that, but oh well worked for me hope it works for others with a hoover steam vac.
Jan 04, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Leaking from bottom
It is the steamvac pump that is bad. When you fill up the tank with solutions, even though it is not running the solution leaks out, and when you turn it on it sprays up and out the sides etc. Also the attachment doen't work either, no solutions comes out. Apparently the float sticks in this. My husband fixed it once, and now he can't, need a new part. Options are take it to a hoover service dealer, or I found 2 place online that sell the part. One is http://buyitnow64.stores.yahoo.net/hostrepufor5.html and the other is http://www.sweeper-city.com/ho5brstpu.html, this site if you look at different size pumps have a description of the problem: "If your Hoover Steam Vac is leaking or water will not come out of the attachment hose, then this is the part that you probably need !!!
This part is for F5914-900 model. Hope this helps
Aug 29, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Cleaning uphoustry
Furniture cleaning isn't a science: try out a few techniques before choosing the one that is right for your belongings. This step-by-step guide explains how to clean a sofa:
  1. Before using any upholstery cleaning products, vacuum the sofa or chair first to remove as much surface dirt and dust as possible. Be sure to use the correct attachments to avoid damage to the material - a soft brush attachment is ideal.
  1. Spot Clean. Using baby wipes or vinegar poured onto a strong microfiber cloth, apply to any obvious stains, wiping gently as you go. Remember to test the upholstery cleaning products on an inconspicuous area first.
  1. Overall Clean. Using soapy water and a microfibre cloth, gently wipe your sofa with the solution, allowing it to soak into the fabric and tackle the dirt beneath the surface. You only want to use a very small amount of water - don't saturate the material.
  1. Dry. Some people use a hairdryer to quickly dry a sofa, but allowing it to dry naturally is always the better option, if you have the time. To speed things up, open windows and allow the breeze to help with the drying process.
House Office Carpet Residential Commercial Cleaning Geelong Commercial...
Apr 23, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Upright SteamVac Deluxe with stair and upholstery cleaner
Don't listen to Solution #1, it is simply NOT correct. This is the correct answer:
As you stated, you already know where the water hose connection is. It is under the easily visible port cover on the top of the base.
What is NOT easily visible is the connection for the vacuum hose. That's because the machine needs to be "reconfigured" before the hose can be attached. To "reconfigure" the machine:
1) Remove the cover off the waste water tank and notice how things appear--it will soon be important.
2) Find and remove the "panel" on the front of the waste water tank by sliding it straight up and out.
3) Replace the panel with the connector by sliding it straight down. When finished the top should look something like it did in step 1). This assures that the dirty water will be vacuumed into the waste water tank.
Done!
Oct 23, 2007 | Hoover F7220900 SteamVac V2 Upright Vacuum
Hoover V1 SteamVac SpinScrub Vacuum Logo
421 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
