Gaggia Classic Espresso Machine
Problem for Gaggia Classic Espresso Machine
After descaling my classic, no water is coming out
By brcbarnes on Nov 05, 2009
I went through the first stage of de-scaling - 20 second operation, waited 20 minutes operated the machine again and now no water is coming out of the machine head. Steam comes out of the frother ok.
Before I started to de-scale, I removed the metal filter and cross head screw from the machine as per instructions.
What should I do next ??
Solution #1
posted on Nov 26, 2009
Not Rated)
andrew247
Rank: Apprentice
Rating: 0%, 0 votes
I have exactly the same problem.
I have taken the whole thing apart and tried descaling the brew head when it was off, by soaking it in descaling solution.
Reassembled ... and exactly the same as before.
ESWorld - Where is the valve in the brew head and what hoses should I check for blockages?
Thanks!
Was this helpful?
Yes
No
Solution #2
posted on Nov 06, 2009
Not Rated)
EsWorld
Rank: Guru  Kitchen Appliances  Expert
Rating: 86%, 332 votes
Try running the descale again it is possible that some of the minerals got loose and blocked the valve in the brew head. If that does not work then you will have to open the machine and unblock the valve or hose that is clogged.
Was this helpful?
Yes
No
Popular Solutions for Gaggia Classic Espresso
Questions and Unsolved Problems for Gaggia Classic Espresso
Do you recommend Gaggia Classic Espresso Machine?
Answer
Answer
I have a Gaggia Classic coffee machine which I haven't used for some time. I filled the resevoir... (More)
Answer
HI. my problem stems from not enough water coming through the brewing head. there is a small amount... (More)
Answer
started up gaggia classic for the 1st time today. followed the instructions in the manual but when... (More)
Answer
I need to purchase a new Turbo-Frother for my Gaggia Classic coffee machine but don't know where to... (More)
Answer
Its brew very slow even without coffee, i clean it everything whats next? I think the pressure its... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Gaggia Classic Espresso...:
Top Coffee and Esp... Experts
Rank: Guru Guru
Solutions: 2520
Experience: ASE Certified Master Car and Truck Mechanic Certified AC mechanic Cert. AWS Cert. welder Contract me
Ask Me
Find more Coffee and Esp... Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
