Question about Tascam DP01 All-In-One Recording Package Microphone
Tascam DP01 wont get past please wait screen
When I turn the power on the screen shows the name, Tascam DP-01 then underneath says please wait. please help me
  • TheZ Mar 22, 2009
    I was wondering how exactly you can reformat the drive using my PC. I have the same problem and I have tried connecting the drive using a variety of ports and my computer doesn't even realize that it's there, or so it seems. What should I do?
    Novelist:
  • 189 Answers
Usually an indication of bad sectors on the hard drive. This can be caused by bumping the unit when it is running, excessive vibration, a power failure while it is on, improper shutdown, or expoure to a strong magnetic field like having a subwoofer too close or an intermittent faulty power supply.
Your options are to return the unit (if it is still under warranty), or if not to open up the DP-01, remove the hard drive, connect it to a PC and perform a low level format (or take the drive to your nearest PC repair shop and have them reformat it).
Unfortunately you'll lose any data that wasn't backed up, but this should bring back your DP-01.
Posted on Jan 05, 2008
  • Dave Hart Jan 05, 2008
    Alternatively with the low price of 40Gb hard drives these days you may opt to simply replace the hard drive and save yourself the trouble of having to reformat or troubleshoot whether the drive failed for some more serious reason.
    New Friend:
This happened to me, but I found out it was due to a power supply issue NOT supplying quite enough power for the machine to spin the hard drive correctly. Try a new power supply, I did and it fixed the issue correctly.
Posted on Oct 19, 2017
    New Friend:
I have the same problem. 2 times already done a low-level format, but it still does not work, then what is going on or should I do something else?
Posted on Nov 30, 2014
TASCAM DP-01 won`t startup
Press and hold down the "track edit" and the "shut down" buttons while turning the power on until it says "-init screen- please wait". It will ask you if you want to initialize hdd. If so press yes/enter. This Will wipe your hard drive clean. If no just press no/exit. This works on the dp-01fx. It should work on the dp-01 as well.
Dec 02, 2014 | Tascam DP01 All-In-One Recording Package...
TASCAM DP-02 (You don't even include it here in your products!)
Here's a link to the DVD tutorial for the DP-02:
http://www.amazon.com/Tascam-DP-02-Video-Tutorial-Manual/dp/B001JP6572
There is also a video on Tascam's support page for this product that you can download for free:
http://www.tascam.com/products/dp-02;9,16,3580,19.html
You can ask questions here or consider joining Tascam Forums (I think it costs $4) and talk to Tascam experts from all over.
http://www.tascamforums.com/
The DP-02 operates almost exactly as the DP-01 did, so manuals and videos for one should pretty much guide you correctly when applied to the other, but the video in the first link is the correct on for the DP-02.
Hope this helps.
Best of luck.
bd.
May 08, 2009 | Tascam DP01 All-In-One Recording Package...
What kind of driver does my tascam dp 01 cd take.
No CD comes with the DP-01. The Tascam relys on your computers USB drivers to work.
You should probably try the DP-01 on someones else's computer first to se if it works there.
This is usually some kind of incompatiblity between the usb cable or the use hub and the usb speed (1.1 or 2.0). I would try bypassing any usb hub you might have in use first. If that doesn't work you might want to try another usb cable.
Good luck.
bd.
Jul 23, 2008 | Tascam DP01 All-In-One Recording Package...
Need a manual
Here is the location for the manual:
http://www.tascam.com/products/dp-01;9,16,33,19.html
That site has the quick install guide as well as the manuals for the different dp-01 models.
Jun 19, 2008 | Tascam DP01 All-In-One Recording Package...
Tascam Portastudio DP-1FX/CD When I turn it on I get this message. Err: 12 Please PWR OFF
This is basically an error message which indicates that the Tascam timed out while waiting for the drive to spin up. Usually an issue with the drive motor not getting the correct amount of power.
Primary suspect is usually the power adapter.
Cheers
BD
Apr 22, 2008 | Tascam DP01 All-In-One Recording Package...
(need more tracks) dp01
I'm guessing that you're asking whether the mixer needs phantom power to the mics in which case the answer is that you wouldn't need power there if the mic preamp is providing it already. You'd just plug the mixer's main 1/4" outputs into the DP-01s 1/4" inputs. The 1/4" inputs on the DP-01 are not powered anyway, only the XLR jacks can be powered by turning the phantom power switch on.
Apr 02, 2008 | Tascam DP01 All-In-One Recording Package...
My power went out when i was formating disk
you need to take out the hdd from the unit and reformat it in a computer. then reinstall in the dp-01 this should take care of the problem.
Jan 21, 2008 | Tascam DP01 All-In-One Recording Package...
Hooking my tascam dp01 to the pc
hey i had the same problem u need u.s.b 2 or something like that because some computers have u.s.b. 1.5 or something wierd along those lines i fixed mine by plugging mine into the back of the computer in the usb port there.
Sep 25, 2007 | Tascam DP01 All-In-One Recording Package...
Tascam DP01 All-In-One Recording Package Microphone Logo
2,523 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
