Home | HP | Color LaserJet 2600n Printer | Paper Jam
HP Color LaserJet 2600n Printer
Problem for HP Color LaserJet 2600n Printer
Paper Jam
By dbaxter95 on Nov 05, 2009
Little piece of paper is stuck in the roller under the hood where the paper is suppose to come out.
Solution #1
posted on Nov 08, 2009
Not Rated)
manm
Rank: Wiz
Rating: 71%, 7 votes
try to feed tick media as coated or glossy which may push small paper bit from that location
or open the rear side door and push the lever on two side of printer to release the fuser grip and clear the paper from where you may access it’s easily
Was this helpful?
Yes
No
Solution #2
posted on Nov 07, 2009
Not Rated)
Soulvisitor
Rank: Guru  HP Computer Hardware  Expert
Rating: 88%, 2349 votes
Not easy, thats the fuser, normally it is damaged and beyond it causing paper to jam there, no easy fix, cant pull it out without major screwdriver challange...I think thats this one... some fuser s(hot bit that paper exits), are pop out by green release tabs but if I have my models right these are the cheaper version and they fix them to the machine thus ensuring you upgrade..modern world..
Was this helpful?
Yes
No
Popular Solutions for HP Color LaserJet 2600n
Questions and Unsolved Problems for HP Color LaserJet 2600n
Do you recommend HP Color LaserJet 2600n Printer?
Answer
Answer
magenta very pale. I have put a new cartridge in.
Answer
When I print a page with color across the entire width of the page, the colors on the left hand side... (More)
Answer
My 2600N HP color laserjet, The colors are not lined up, Printer needs to be manually calibrated.... (More)
Answer
there are 3 diagonal indentation stripes in paper
Answer
Change print status from Offline to online on HP 2660
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For HP Color LaserJet 2600n...:
Top Printer Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
