Toshiba SD-R6372  DVD±RW Burner
Problem for Toshiba SD-R6372 (SDR6372S) DVD±RW Burner
Slideshow
By csepke51 on Jan 05, 2008
I try to create a slide show with background music ,it gets all the way to overall prgress97% and current task-closing project15% then the computor freezes!
Comments:
Jan 05, 2008
- this is not a toshiba dvd burner , it is on my dell systemE310 dimension
Jan 05, 2008
- It's by sonic Roxio media creator suite10
Solution #1
posted on Jan 05, 2008
Not Rated)
DARKLORD1
Rank: Guru
Rating: 86%, 727 votes
Well i think its software rather than hardware, What program are your using and are your songs mp3, or wma. or wav.
Here is what i suggest
1.) download nero from here http://www.phazeddl.com/ just search nero
2.) install it and folly the instructions to get it activated
3.) Use nero vision express
start / all programs / nero / photo and video / nero vision
4.)create a slive show dvd
5.) drag across your photos
6.) drag across your audio
7.) right click on the time line and set your transitions and time etc. basically set it up how you would like it to look
8.) burn it ( nero vision doest that for you automatically)
its user friendly and self explationary and very very very easy to use and is gurantied to work
NB. for better compatibality convert mp3 files to wav file.
to do this open it in nero wave editor and save it as a wav file
:) cheers
Comments:
Jan 06, 2008
- USE THE NERO INSTEAD OF ROXIO, ROXIA DOES A PISS POOR JOB AND STALLS AT THE SLIGHTEST DEFECT OR CHANGES IN YOUR MP3's bitrate,, THERE FOR THE PROBLEM THAT IS CASSING IT TO STIC IS ONE OF THE MP3 FILES YOU ARE USING more than likely the lsast one, convert it to a wav file and it should work.. I strongly suggest you download and use nero from the link i provided ..
Solution #2
Not Rated)
amanzoor
Rank: Guru
Rating: 87%, 90 votes
csepke51:
Could you please tell the name of the program through which you are trying to burn. Also which OS.
Comments:
Jan 05, 2008
- Please try to change the path of the proxy file or temp file in Roxio, reboot your machine and try again. make sure you have enough HD space.
Solution #3
Not Rated)
fwadley
Rank: Wiz
Rating: 78%, 465 votes
try closeing all other groprams that are running in the background and this should give you some more memory.
Solution #4
Not Rated)
Lemmor
Rank: Wiz
Rating: 84%, 616 votes
FIRST OF ALL WHEN BURNING YOU SHOULD HAVE CHECKED THE FOLLOWING: (1) HAVE ENOUGH SPACE ON YOUR HARDDISK, (2) MINIMUM OR NO APPLICATION IS LOADED ON YOUR SYSTEM WHEN BURNING. (3) AT LEAST YOU HAVE ENOUGH MEMORY TO PROCESS YOUR WORK.
CHECK YOUR HARDDISK YOU SHOULD HAVE AT LEAST 1GB OF FREE SPACE. IF NOT, ERASE FILES NOT NEEDED ANYMORE TO FREE UP SPACE ON YOUR HARDDISK.
WHEN BURNING, DO NOT LOAD OTHER SOFTWARE THAT CONSUMES MEMORY NEEDED WHEN BURNING.
YOUR COMPUTER HAS A GOOD SPECS... YOU SHOULD MAKE SURE THAT YOUR COMPUTER IS FREE FROM VIRUSES.
Popular Solutions for Toshiba SD-R6372 DVD±RW
Questions and Unsolved Problems for Toshiba SD-R6372 DVD±RW
Do you recommend Toshiba SD-R6372 (SDR6372S) DVD±RW Burner?
Answer
Answer
i have a mad dog dvd burner but no program to burn dvds what is a good one. my main goal is to rip... (More)
Answer
I have an Acer 5310 and want a DVD burner internal or external. Can you recommend please
Answer
I have a fujistu laptop and I bought Memorex cd-rw disk. A Man I work with knows how to do this, but... (More)
Answer
I use to backup all my staff's on dvd-rw... now I'm not able to write a simple cd... only small... (More)
Answer
My computer will upload the movie onto my computer but when it ask for blank media it will not read... (More)
Describe your CD and DVD Burners problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top CD and DVD Burner Experts
Top Computer & Laptop Repairmen
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
