Cars & Trucks Logo
Posted on Nov 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am getting no sound from my computer speakers, & a screen keeps popping up showing volume audio @ 0
  • Paul Hutchinson May 11, 2010
    go into the control panel, (start,control panel) and select the sound(and audio devices) icon. Set the volume levels from there and check that mute is not "ticked"
Anonymous
Level 2:
  • Expert 437 Answers
  • Posted on Nov 05, 2009
Anonymous
Expert
Level 2:
Answers
437
Questions
0
Helped
130842
Points
562
What year BMW and series is this one?
Volvo 2000 s 80 Radio/CD player screen lights up, but nothing comes out of speakers. Occasionally, I will here a speaker pop. How 2 diagnose? Water on floor. Possible damaged amp?
doesnt sound good ..water there
could be bad earths
amp may have a fuse
speakers need to be tested manually
these links may have wiring layouts etc
VOLVO Car Radio Stereo
Audio Wiring Diagram Autoradio connector wire...
Volvo Radio Wiring Diagram
I have an 2002 Nissan altima and DA display on the radio is working but no sound
Hi candy Love , I love that name ! What Altima ? S ,SE or SL
AUDIO
Revision: May 2004 2002 Altima
AUDIO PFP:28111
System Description EKS002KQ
BASE AND MIDLINE SYSTEM
Refer to Owner's Manual for audio system operating instructions.
Power is supplied at all times
 through 15A fuse [No. 31, located in the fuse and fusible link box]
 to audio unit terminal 6.
With the ignition switch in the ACC or ON position, power is supplied
 through 10A fuse [No. 6, located in the fuse block (J/B)]
 to audio unit terminal 10.
Ground is supplied through the case of the audio unit.
Audio signals are supplied
 through audio unit terminals 1, 2, 3, 4, 13, 14, 15, and 16
 to terminals + and - of front door speaker LH and RH
 to terminals + and - of rear door speaker LH and RH
 to terminals + and - of tweeter LH and RH.
BOSE® SYSTEM
 to audio unit terminal 6, and
 to Bose speaker amp. terminal 1.
Ground is also supplied
 to speaker amp. terminal 17
 through body ground B117.
 to speaker amp. terminals 23, 24, 25, 26, 27, 28, 29, and 30.
Audio signals are amplified by the speaker amp.
The amplified audio signals are supplied
 through speaker amp. terminals 2, 3, 9, 10, 11, 12, 13, 14, 15, 16, 18, and 19
 to terminals + and - of subwoofer LH and RH.
SPEED DEPENDENT VOLUME CONTROL (MIDLINE SYSTEM AND BOSE SYSTEM)
If activated, the radio output volume will be automatically adjusted to compensate for increased driving noises
at higher driving speeds.
The radio receives a vehicle speed signal from the combination meter, and selects the output volume.
Dennis my 1995 lincoln towncar JBL radio quit producing sound the system comes on fine but I get no sound could u help me please, what is the problem?
The Amp in the trunk might have blown,
Town Car Radio Wire Diagram
Car Radio Battery Constant 12v+ Wire: Pink/Light Blue
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: Blue/Red
Car Stereo Antenna Trigger Wire: Blue
Car Stereo Amplifier Location: Trunk
Car Audio Front Speakers Size: 5? x 7? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Car Audio Rear Speakers Size: 6? x 9? Speakers[img src="http://www.assoc-amazon.com/e/ir?t=modilife-20&l=as2&o=1&a=B00009UHRE" width="1" height="1" border="0" alt="">
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Check the fuses
24851106-prgqozi4aluuon54ixeydqz4-5-7.gif 24851106-prgqozi4aluuon54ixeydqz4-5-0_0.jpg
Radio sound low and squeeky, works good in summertime
The volume control on your radio is called a potentiometer, which may be going bad. It works better when its warm because materials expand as they warm up and make tighter contact with each other.
It is also a possible a bad wiring connection exists. Poor contact will cause static, poor audio quality and intermittent output.
Your radio will have plug type connector(s) Your speakers will most likely each have two wires with single female spade connectors of different widths (keeps the polarity correct) the wire with the stripe (of whatever color) will be connected to the negative (-) speaker terminal.
So you need to check all the connections, one is making poor contact.
If both speakers (assuming you have two) sound good or bad... then start with the plug connectors for the radio and any independent black ground wire coming out of the radio.
If one speakers sounds okay check the connections on the other one. You check the connections by carefully pulling the speaker wire off of the speaker and then carefully pushing it back on making sure it feels tight and secure.
PS: If you pull the fuse for the radio, the radio will have no power and will not work. The radio coming on proves the fuse is good.
PSS: Your owners manual should provide lots of information on your sound system components.
No sound coming from speakers
This is why cars with computers are not a good idea.
2000 chrysler grand voyager Integrated speaker amps???
Replace the speakers if they are amplified types.
There is no sound coming from the speakers, not even the bluetooth. The volume control on the steering wheel and the knob also doesn't work. The radio, cd & dvd player work fine.
So everything is coming on but you have no sound from anything?If that is the case you may want to check the amp fuse.The car has a factory amp i'm trying to remember i think it is in the trunk.Look in your owners manuel for the fuse box location.If the fuse is good then the factory amp may be bad.Or you may have a blown speaker that is showing a short and putting the amp into protect.If the amp and or speakers are bad i highly recommend just buying after market speakers/amp.The price for the factory equipment is very high and there labor rates even higher lol.Plus if properly installed you will noticed better sound from the after market stuff as long as you get brand name equipment.Go to a well trusted audio shop in your area they should be able to see if it is a speaker or amp problem if your fuses are all good.They should be able to test the impedance of the speakers at the amp for you and see what is going on.
2answers
Radio on 2008 dodge nitro stops working it goes out for a while then comes back on. no sound even when turning the volume up and down. it makes a loud popping noise and goes out.
Im having the same problem! No pop, just a hum, and my volume dial won't adjust. Like the actual dial isn't working. I can't use radio, cd, or aux. Silence SUCKS.
1helpful
Volume low on all four speakers, some static (amp or head unit problem)
I would check the amp first, especially if you have very low sound on the speakers. Before amps were made, bad output transistors would create the same effect.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
