Question about Intel Motherboard
New install of msi mainboard, no display on monitar or cd rom work
I just installed an msi motherboard, connected the hard drive and cd rom, when powered up, no display on monitar, and cd rom power light/tray open will not work. help....
    Problem Solver:
  • 19 Answers
Reinstall ur motherboard and cheak properly that ur mbo dont touch with earthing ( cheak ur power supply proper earthing )
Posted on Jan 05, 2008
How can i install windows 7 on a new sata ******* a msi k8n neo4 motherboard with mainboard cd?
it has nothing to do with the motherboard make sure you format the hdd before you install the OS
Jan 31, 2012 | MSI Computers & Internet
I have a GF615M-P33V2 - how can I get Windows Server 2003 drivers and software? Also, IDE CD/DVD only work intermittently. Is there any way I can connect a CD, DVD and a floppy. I've already an IDE HD...
Hi, the download site is here:
http://www.msi.com/product/mb/GF615M-P33.html#/?div=Driver&os=All
But there is no drivers for windows 2003.
The 32 bit driver for windows xp will sometimes work
if it is a 32 bit system.
You can buy an external floppy drive and a cd/dvd drive to
connect the usb.
But the mainboard has a connector for the floppy drive.
Try to install the chipset drivers first and unzip the file before installation.
Consider to buy a mainboard compatible with windows server 2003
I will recomend a ASUS mainboard.
Sep 17, 2011 | MSI GF615M-P31 AM3 NVIDIA GeForce 6150SE &...
SUPER X5DPA-GG mainboard doesn't find connected ide hard drive. All bios and mainboard drivers are current. Board finds cd-rom in ide 1 and 2 but wont read any hard drives. IS THE MAINBOARD FRIED. IDE...
Never put the CD on IDE 1
The IDE hard drive should always be alone on the first IDE channel.
CD-ROM drives can slow down the transfer rates and cause other screwups, and so they should always be on IDE2 or as high as possible (Add in Cards)
Sep 05, 2010 | SuperMicro X5DPA-GG (672042882748)...
I have no audio after reformatting,....how can i
did you re-install the mainboard drivers after the reformat of your hard drive?? you should have a disk of drivers for your mainboard but if not, go to the LG website as you can download and install them from here through the support portal. you may need to install a cd audio driver as well but usually not.. Install the mainboard drivers first as this should cure this issue and yes, the PC will reboot at least twice during this procedure and this is nothing to worry about..
Nov 02, 2009 | LG IBM LENOVO LCD-LIQUID CRYSTAL DISPLAY...
Hoew to install CD Drive
You want to install a CD Drive. Ok you are Following these steps....
  1. Unplug the power cable from your power supply and open your Computer case.
  2. Determine which drive bay you are going to install a CD-ROM into. You should pick on of the uppermost drive bays
  3. Before you install a CD-ROM, make sure you have the proper jumper settings. You are only installing a single CD-ROM, set the jumpers as MASTER. The jumper settings are different for each CD-ROM drive, so consult your owner's manual so you know which pins to cover up.
  4. Once you have the jumpers set, install your CD-ROM in the computer's case. How you secure the CD-ROM in one of the uppermost drive bays depends on your case. Some CD-ROM drives have to be screwed into the drive bay.
  5. Connect the power to the back of the CD-ROM drive, then connect the ribbon cable to the back of the CD-ROM drive. Your ribbon cable has three connectors, one in the middle and one on each end. The middle connector is a SLAVE connector that is used if you would install an additional CD-ROM or DVD-ROM drive.
  6. Connect one of the end connectors to the CD-ROM drive, and connect the other end connector to the appropriate spot on your motherboard. Note, hard drives and CD-ROM drives have the same style of connector on the motherboard. You want to connect your CD-ROM drive to the motherboard slot that isn't red or is the highest numbered of all the IDE slots.
  7. Power on your computer after you plug it in. Your computer should recognize the new CD-ROM. If it doesn't, go into your motherboards BIOS and search around for the IDE channels, they need to be set to automatically.
Thank U
Aug 28, 2009 | LG Computers & Internet
When I push the start button the fans rotate for a second or 2.
ANY BEEPING NOISES, ANY FLASHING COLORED LIGHT.
SOUNDS LIKE ALOT OF COMPONET ERRORS AND CONFLICK ISSUES AND EVERYONE HAS TO BE FIXED 1 ITEM AT A TIME YOU MAY GET LUCKY AND FIX ALL THE PROBLEMS IN 1 SOLUTION BUT I DONT THINK SO.
YOU ARE HAVING IRQ AND DMA ERRORS
RODGANDYSR
Mar 13, 2009 | MSI Matx G31 LGA775 DDR2 (G31M3F)...
Driver
Try this link
http://global.msi.com.tw/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=592
I hope it helps!!!
Nov 17, 2008 | MSI K7N2 Delta2 400FB nForce2 Ultra...
Msi pm8m-v series micro-atx mainboard is not detecting 160gb seagate sata harddrive
Had u properly connected the driver to motherboard..?
U can change the sata cable. Check the power connection also.
Jan 19, 2008 | MSI PM8M-V Motherboard
Installation
unplug you hard disk, then switch on without your hard disk let your xpcd in your cd rom to run after reading your cd ''saying, no hard drive found'' switch off then plug it in your installation will proceed
Nov 27, 2007 | MSI K7N2 Delta-ILSR (MS-6570-030)...
Msi motherboard
Try using the cd rom on the second cable as a master.
Let me know whats up
Nov 15, 2007 | Intel Motherboard
Intel Motherboard Logo
96 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
