Question about T-Mobile Sidekick
Connecting my sidekick id to my pc.
I tryed to connect my skid to my pc and the new hardware wizard thing popped up. Is there a website i can go to so i can get the software for my pc?
  • 1 more comment
  • Anonymous Nov 15, 2008
    MY SIDEKICK ID DONT ' LET ME GO TO MY PC
  • Cris14 Jan 23, 2009
    i have the exact same problem...plz help me...
  • Anonymous Mar 22, 2009
    cuando lo conecto sale que ne sesita los dribe como consigo los dribe
    President:
  • 625 Answers
Try http://developer.danger.com/. signup and download the software. It's not technically supported but can be done.
Posted on Jan 05, 2008
Found new hardware bubble pops up then mouse and keyboard freze
disconect all the things that is connected to the pc and do them one at a time
Mar 12, 2010 | Dell OptiPlex SX280 PC Desktop
Unable to connect Nokia 3120 Classic with PC
Souns like you need to reinstall the Nokia software. Just pop in the CD and run the setup wizard again. Reboot computer when you are done and try connecting your phone.
If you need further assistance, let me know.
Regards,
Jedi
Mar 20, 2009 | Nokia 3110 Cellular Phone
Usb connect with sidekick id
The Sidekick ID doesn't support being connected to the PC. That is why the usb port is hidden.
The only way to make it work is if you get the developer software and key.
Sorry
Dec 13, 2008 | T-Mobile Sidekick ID Cellular Phone
Usb for sidekick id
Trackenerdzz-
The sidekick ID doesn't support USB. With the sidekicks, the only thing you see when you plug it in to the computer is the memory card. The Sidekick ID doesn't support memory cards so you will not see anything......Unless you get a developers license.
Problem with sidekick slide memory card downloads
Same thing happend to me.
either get a new usb cable that suppoorts it well,
or Put your memory card in the Memory card slot on your PC (if you have one) and it should pop up
Nov 19, 2008 | T-Mobile Sidekick
Can u help me with my sandisk sansa m230 mp3 player plz!! thank u
Windows cannot find a suitable driver - I would reinsert your installation CD, and THEN run the Found New Hardware Wizard.
Jun 28, 2008 | SanDisk Sansa m230 MP3 Player
Trying to install HP C4280, fatal error comes up during installation and will not complete
To install that printer, connect the data cable (Maybe USB?) to the PC and follow the instructions on the "New Hardware found" wizard, then supply the CD that came with the printer and make the wizard look for the drivers there. When the HP install program pops up (Gray sandglass), choose "Decline" or "Not agree" to the terms of the license and continue with the "New hardware wizard" installation.
The printer driver will get installed and none of the HP useless programs.
May 04, 2008 | Office Equipment & Supplies
IFP-380T MP3 Player Problem (doesn't turn it on)
Here's my shortcut:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Here is a suggestion from the iRiver website - you may want to visit that website, b/c their "Ask Alice" tech support feature is actually quite good:
The players come with a CD that contains drivers and software that enable the player to download data from a PC. Insert the CD in the computer's CD drive, and connect the player to the PC with the USB cable. (Help with USB cable connections) The PC should automatically detect the device. The New Hardware Installation Wizard will automatically launch and the installation process will start.
If the above procedure does not occur on your PC, please manually install the driver. Use the links below for instructions:
If you still have trouble, the issue may be with the computer chipset. iriver has tested many PCs and discovered that this only occurs in a small number of main boards.
Apr 19, 2008 | iRiver iFP-380T MP3 Player
Mp3 philips hdd082/17 not charging and not connected when connected to usb
WARNING: this process will erase all songs off the GoGear.
Disconnect the GoGear from computer.
Turn the GoGear off.
Hold in the volume + button.
Reconnect the GoGear while holding in the volume + button.
Continue holding the volume + button.
After 5-50 seconds, Windows will pop-up a "Found New Hardware Wizard." - complete the wizard (BTW, you can take your hand ff the volume + button now).
Good To Go (Gear)!
-Tha Mp3 Doctor
Mar 24, 2008 | Philips HDD082 MP3 Player
Hey
try{MS_AddEvent(window, 'load', function() {try{CreateAC({id:'query', lcid:'1033', initialValue:'', acURL:'http://autocomplete.support.microsoft.com', statsObj:StatsDotNet, startChar:'4'});}catch(e){}});}catch(e){}
Make sure the hold/lock is not engaged
Make sure the OS is compatible
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Dec 11, 2007 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
T-Mobile Sidekick Logo
560 people viewed this question
Top T-Mobile Computers & Internet Experts
ismael castillo
Marvin
Marvin
Edward Talavera
Edward Talavera
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
