Question about Maytag Neptune FAV6800AW Top Load Washer
Problem Magtag TL
Hi, My three year old Maytag Nuptune TL works fine when empty. But when I add cloths within the washer and run it. It runs but starts surging in periods of 30 seconds and stops. When the digital timer get down to the spin cycle with 12 Minutes leftthe washer shuts down and the digital read out reads UC? Also when it starts to spine the washer starts to shake badly? This all just started. We have already paid an appliance repair company over $300.00 dollars and he was unable to fix the problem.
Thank you,
Jerry Jones
  • 283 Answers
UC means the washer cannot spin. There's a bulletin out this.
The clutch is likely the cause of these error codes, preventing the unit from spinning freely. A new clutch was introduced in production in March 2005 to improve performance and should reduce these error codes.
1. Visual verification can be made of a malfunctioning clutch by observing the lifter operation in spin. The lifters will rotate up to one complete rotation just prior to the tub starting to spin counter clockwise. Should the lifters continue to rotate while the tub spins, examination of the clutch will be necessary.
2. Inspect the 14 wire plug in the control console for loose red\white- pink- blue\white from the P3 connector. Also inspect the wires and connection point on the Tub Displacement Sensor for corrosion. Measure from PK to Wh/Bu at the P3 connector. The voltage should be approximately 1.5vdc when the tub is centered, 3vdc when the tub is pushed to the right rear of
the cabinet and 0vdc to the left front. Any variances of these voltages, the 14 pin harness connection, tub displacement sensor, and sensor connector should be checked.
Posted on Jan 05, 2008
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
Jun 29, 2005
More results from
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
Jan 11, 2016 | Maytag Neptune MAH5500B Front Load Washer
Leaking maytag
it could be the pump but there is a seal in the tube where the transmissin goes through the tub that seal has a common problem of leaking but if it 10 years old i would replace the machine
Jun 14, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Top Loader Thumps When In Spin Cycle
My guess is that one of the three counterweights have separated from their support. Probably rusted away.
36 years is quite a feat. Today's machines would be lucky to 1/3 of that life.
Sounds like its time to go shopping.
Do you have an anniversary coming up?
Ladies love washers for an anniversary gift.
May 24, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Clothes are sooaking wet when cycle finishes and they smell bad
The wetness is due to the spin cycle either not working properly or not being allowed to finish. For the smell, with the washer empty, run a cycle on hot/whites with bleach only, after the first cycle drains, open the washer and add more bleach directly into the washer.
Apr 20, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Oil leak from bottom of maytag neptune tl - about 4 years old
sounds like seal leak in tub water is leaking onto drive unit and washing over it bring and oil it can with it couls be big bucks some parts may be under warranty call service but be sure to get estimate first
Nov 27, 2008 | Maytag Neptune FAV6800AW Top Load Washer
I have a magtag neptune TL washer that stops after each spin cycle and gives a LL or LO on the timer screen. I can open the machaine and fix the clothes. Sometime this works snd then again it does not. I...
There is a service brochure inside the machine and you can access the info on the self tests by finding this brochure. It may be that one of the springs or balancers on the drum holder is bad, loose or broken.
Jun 09, 2017 | Washing Machines
Maytag Neptune TL.
easy!the water pressure switch is not working the little hose going to it could blocked or off,or the pressure switch bottle could be blocked. rate me if right Eire
Dec 02, 2007 | Maytag Neptune MAH5500B Front Load Washer
over 5 years or cost over 250?
 throw it away, and get a Whirlpool
Oct 21, 2007 | GE Profile Prodigy WPSE4200A
Maytag Washer, Neptune TL
This means the computer is not seeing that you opened the lid between cycles 3 times. So likely the lid locks are faulty. PLEASE rate my help as solved all other ratings dock us
Oct 02, 2007 | Maytag MAT13MN Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
110 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
