Question about Protron PLTV-37 37 in. LCD Television
I"m trying to use my Protron Pltv 3750 as a monitor for Mac Mini
When I use plug VGA cord to monitor and turn on mac. My screen goes blue and my power light is red. How do I fix this problem.
  • EB33 Jan 05, 2008
    Please help I would like to use tv as a monitor also.
Mine only works with 1024x768 resolution.
Posted on Jan 16, 2008
Blue screen and power button red
protron pltv-27 cm screen lights up then green comes on and turns red no signal.
Sep 27, 2012 | Protron PLTV-32 Television
My pltv-3750 dosent turn on
my tv will power on and the screen just stays blue
Dec 05, 2011 | Protron PLTV-37 37 in. LCD Television
OK, mini display port to VGA adapter-is the VGA cord the one that goes into the port labeled RGB and audio on the back of the Samsung? Sorry to be a dummy but Samsung monitor is 6 years old and has always...
An RGB port is for a component cable not a VGA cable. A VGA cable, similar to a component cable, only carries a video signal but is a 15 pin cable that nearly all monitors and HDTVs support. Most laptops have a VGA out port.
You should be able to connect your laptop to almost any monitor (not sure about your Samsung) with a male to male VGA cable.
Good luck and thanks for using FixYa.
Mar 09, 2011 | Computers & Internet
I have the protron 3750 the power light is red when i turned the power on the light turned green for a few second then turned red again and nothing happened. can you help?
Tries unplug,replug the tv like an hour later,the tv,now will reset itself back to the factory setting,tv should work now.Not,than the power supply board is having problems,not giving wright voltages to the tv anymore.The power supply board,that the board,where the power a/c cord plug into it.Tries websites like, to buy a refurbish power supply board for the replacement.
Oct 25, 2010 | Protron PLTV-37 37 in. LCD Television
Everytime i conect my monitor into my mac mini the screen shows up for a brief second and disapeers. How can i fix this
You need to lower down the screen resolution. Check the setting of your mac mini then adjust the screen resolution to the lowest.
Jun 09, 2010 | Acer V193w LCD Monitor
I am getting a "no signal" on the blue screen on DTV mode of my Protron PLTV-3750 LCD. It has worked until I moved it to a different room. The signal is good on other tv. Anything I can do?
First make sure you have your cables connected securely, then try to move your antenna around and rescan your channels everytime you move the antenna.
Dec 01, 2009 | Protron PLTV-37 37 in. LCD Television
Same power trouble on Protron PLTV-3750
It seems like the voltage that is powering up the microprocessor is not working properly and the power supply will need to be service.
May 03, 2008 | Protron PLTV-37 37 in. LCD Television
Using protron as a monitor with mac
Need to set resolution and refresh rate on the Mac before plugging in to the TV set - had this same problem with a WinVista machine. According to the documentation, the only supported resolutions are:
640x480 60Hz
800x600 56Hz
800x600 60Hz
1024x768 60Hz
1280x1024 60Hz
1280x768 60Hz
1366x768 60Hz
In all fairness, I cannot get the unit to run in 1366x768, though - get out of range. 1360x768 seems to work OK though. Only real problem with the VGA input is that regular text mode on a video card (more of an issue on Windows machines) does not work.
Nov 21, 2007 | Protron PLTV-32 Television
Protron PLTV-37 37 in. LCD Television Logo
165 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
