Question about RCA 32V420T 32" TV
RCA Home Theatre System 51 or 52"? Chassis # PTK169PAAS
We have acquired this TV and the 3 colors are shadowing. Everything seems to work fine except for this. Given the chassis number, can you help us out? Toting thing to the repair place would be a great adventure in itself. It has to justify itself with me real quick, as my husband has it planted in the middle of the living room while he works on it. Any heads up would be appreciated. Thanks! PS: Here are some other numbers on the tag: Model #P46770CK, Serial #413480469
  • 373 Answers
If it is a "minor" convergence problem you can adjust it by going to the menu and scrolling to convergence and follow prompts A cross will appear when you have reached the correct place and you do the minor adjustments as it says. If picture is bowed you have major convergence problems.
Posted on Jan 05, 2008
Set won't turn on. Was working fine last evening. Now nothing.
Reciever RCA RT2500 ' Techlore
www.techlore.com/forum/thread/11889/reciever-rca-rt2500
Aug 20, 2005 - 31 posts - ‎23 authors
hey ive got the rca RT2500 home theater system. .... won't power up) regardless of number of times I try to simulate a 120 V power flash (pulling plug .... My RCA receiverturns on but there is no sound...what can this mean?
Trouble getting sound from home theatre system with my ...
www.tomsguide.com/.../trouble-sound-home-theatre-system-appreciated....
Mar 27, 2013 - TV: Sony Bravia KDL-60EX645 Home Theatre System:RCA RT2906 ...-I've set the television, per the manual's instruction, to "Audio System" and "Audio Out: Fixed." This should allow the TV to turn off its internal speakers and switch .... SolvedI have F & D home theatre system, my rear speakers won't work.
Problems connecting surround sound to LCD TV... - Forums - CNET
www.cnet.com > Forums > TVs & Home Theaters
CNETJul 30, 2006 - Hey I have a 26" LCD TV from Polaroid and a Philips DVD home theatersystem. ... the Audio setup on the tv and TELL it to output the sound via the RCAcables ... However, you would normally turn off the TV speakers with a menu ... I just can't figure out why the TV audio won't play on the surround sound. Anynet+ - Home theater won't turn on with tv
Jun 11, 2015
TV won't turn on
Jun 10, 2015
Audio Return Channel Problem
Aug 23, 2011
rca tv no sound?????
Jan 1, 2006
More results from www.cnet.com
Jan 19, 2016 | RCA Audio Players & Recorders
My lg tv as optical audio out but my phillips surround system dont have any optical audio how can i connect tv audio to my home theatre speakers
Observe the back of your tv and look for audio out it is commonly colored white and red use a rca jack and connect it to your theatre speaker audio in also located at the back of your home theatre, hope this help good day and best regards.
Sep 14, 2011 | Televison & Video
How do you get sound to come from tv out of speakers of home theatre system
It just depends on the tv you have. If you hook up the RCA jacks to the (Audio out) of the TV into one of the (AUX in) ports of the home Theatre system you should be able to geet the sound that comes from the TV to play out the theatre system. If you are watching through a cable box you will need to hook the RCA cables to the cable box (Audio out) too the theatre systems (AUX in), in insted.
Mar 05, 2011 | Televison & Video
Ghosting of picture from a Panasonic home cinema system
There must be a fault in the screening of the internal wiring to the scart outlet in the home theatre system. I simply changed the way the player was connected to the TV and the interference disappeared:-
1.) I used the RCA video outlet instead of the scart lead. Picture quality was not compromised. FYI the Panasonic Plasma TV I have has only RGB video input sockets at the back, so I used a scart to RCA adaptor to overcome this problem of connecting old technology to new.
2.) The surround sound when playing DVDs is generated directly from the home theatre system so there was no need to connect the audio from the home theatre system to the TV
3.) I used a pair of RCA leads to connect the "audio out" from the TV to the "audio in"on the home theatre system to provide the option of TV sound through the home theatre system.
Mar 18, 2009 | Panasonic Televison & Video
No sound from plasma to home theatre
First off it's always best to start from scratch when it comes to home audio. LoL. Many times I've been in this situation.
So with everything disconnected. You should have your HDMI, COMPONENT, RCA(R,W,Y)
HDMI and COMPONENT are the exact same thing and in all preference COMPONENT is far better thand HDMI for the pure fact that each wire is in it's own casing and insualted to avoid feedback from the other wires.
Anyways, with everything disconnected we begin
From you Cable/satellite box- Run your HDMI cable from you cable box to your HDMI 1 input on your tv.(If your speakers were to work on your tv you would automaticaly get sound and picture)
That should be all that you should be running from you cable box. Now that we have one thing running we go to the next thing.
From your TV run your audio out (RCA Red/White) to your amp. Usually your preference but more than likely your TV IN on your amp.
With your amp now set on TV, you should automatically get sound from your tv. and if your running an HD cable box even though your only running RED/WHITE to your amp, you will still be receiving Digital sound.
Most new amps Should have a digital input and if your running and 1080iUp this one RCA plugin will give you dolby digital sound from your dvd player to your amp. Then running a video rca up to your tv, will give you the picture, while the digital out on your dvd player to your amp will give you dolby digital sound.
It's a basic simple step to get sound. Like a continuing current. So just as long as you have your cable to -- tv -- home theatre. Everything should work. Otherwise I would go and check your cables and make sure they are not faulty.
I hope this confusing walkthrough helps.
Jun 23, 2008 | Panasonic TH-42PX60U Television
RCA Home Theatre - Tuner problem
you may coldsolder the tuner first before replacing the new one,maybe it can works.
Apr 30, 2008 | RCA TruFlat 27F520T 27" TV
RCA Rear Projection TV P46770CK spark beneath chassis when power applied
It sounds to me that you may have a cold solder joint ( loose connection on the board ). I suggest you remove the board ( or seek professional assistance ) and solder any loose connections that you may find. That may correct the problem. Good Luck.
Ed
NC Electronics
Mills, Wyoming
Have a Great Presidents Day
Feb 17, 2008 | Televison & Video
Home Theatre System
well u can run direct tv to tv then the tvs master digital out to the rca digital in or anlog rca cable
Jan 27, 2008 | Audio Players & Recorders
RCA 32V420T 32" TV Logo
60 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
