Question about Nikon COOLPIX L3 Digital Camera
The shutter The camera comes on but the shutter is stuck in a half closed position.
  • 797 Answers
Have to know which shutter. If it is the shutter on the end of the lens, then more than likely the end cap is bent, and will jam the shutter. this may be able to be fixed by gently prying up on the bent area , also protect the lens cap with a small piece of aluminum or something similar as you pry gently up ward with a small flat screwdriver. Be very cautious on this, it may do a lot of damage in a split second....so be very careful...if you cannot do it, then someone who is good at repairs of small things may be able to help you.
Notice that you could damage the camera to not be able to be used at all.. so just take note.
Posted on Jun 21, 2008
Screen is black and pictures come out black
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Aug 30, 2011 | Samsung BL103 Digital Camera
Canon PowerShot S3 IS shutter problem. Shutter does not respond. Screen is black. No pictures are seen. It sounds like it it taking a picture, but doesn't. When looking into lens, it doesn't appear the...
Dec 20, 2010 | Canon PowerShot S3 IS Digital Camera
The screen is black and all pictures taken come out black
Sep 28, 2010 | Kodak EasyShare Z1012 IS Digital Camera
When turn camera on screen is black when i take a pic the pic comes out black also
Aug 30, 2010 | Kodak EasyShare C533 Digital Camera
Shutter appears to be stuck closed.
Theirs oil on the shutter blades causing it to stay closed, Thats why you can't see though the lens or the viewfinder also, This comes from the grease from the zoom assy, It's a major job to fix it, Has to be fixed by a repair shop
Jun 04, 2010 | Canon PowerShot S3 IS Digital Camera
I am using canon A430 for 1 yrs bur from bfore 2 mnths when i image on day time the image becomes too bright and when i take at in light i comes parallel lines.i am beliving that u will suerly solve my...
First make sure you are taking pictures in auto, and not in manual (make sure the mode selector dial is not on the little red camera with an M). If it's not...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Now the A430 is not capable of taking 15 second exposures as recommended for the fix. Instead try setting the camera to manual mode, turn off the flash, got to a darkened room, and take a picture. Open the battery door while the red and yellow light are flashing. Repeat as the fix recommends, but please note that there may be only a small hope that this will work as the shutter may be stuck in the open position. This is harder to get unstuck than a closed shutter.
If the above doesn't work, consider attempting Fix 5a listed on the web page. There is some risk of damaging your camera with this fix, that's why I hesitate to recommend it until last.
Jul 04, 2009 | Canon PowerShot A430 Digital Camera
Horizontal lines in viewfinder and in some photographs
CCD FAILURE ! Call SOny they will do it FREE it is a known manufac fault let me know if i can help more see sample advisory sony knows about it !! Pls RATE ME WELL ! Regards zohail http://esupport.sony.com/US/perl/news-item.pl?mdl=DSCT1&news_id=161
Jun 12, 2009 | Sony Cyber-shot DSC-W35 Digital Camera
Shutter is stuck on open position
shutter is stuck half way open and when the camera is turned on it says lens error 0x001110000 and then it shuts off
Apr 30, 2009 | Cameras
Cnon eos rebel half black pictures
Sensor may have something on it....or your f/ may be off. or if you use flash it is probably not on High Flash Sync. Just ask your local photographer, because I can't help unless I actually see it.
Aug 13, 2008 | Canon Rebel XT / EOS 350D Digital Camera
D70 Shutter Stuck
I'm afraid the camera has suffered "shutter death". After a certain number of clicks (usually 30.000-70.000, but it could be as little as 5000 or as much as 150.000), the shutter just gives up the ghost. It's fixable, but expensive.
Dec 17, 2007 | Nikon D70 Digital Camera
Nikon COOLPIX L3 Digital Camera Logo
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
