Problem for Washing Machines
Generic problem for all Washing Machines
Water not going into dishwasher
water not going into dishwasher
Solution #1
posted on Nov 05, 2009
Rank: Apprentice
Rating: 0%, 0 votes
Ck to be sure water is turned on at source.Turn valve handle left to open,right to close.Make sure wtr supply line isn't kinked will be 1/4'' copper,plastic or stainless tubeing.Rubber gasket could have come off valve steam and got stuck in valve outlet.be sure to shut off main wtr valve before cking stop to dishwasher.Solinoid could be defective.Make sure there is pwr to unit.That's about it.Be sure to shut off power before messing with any electrical connections.Be safe and good luck !
Solution #2
Rank: Guru
Rating: 90%, 1140 votes
HELLO THERE:
First you are going to want to check the water connections to make s ure that the screen is not clogged and if they are not clogged then there is a solonoid valve that may have failed when these solonoid valves fail they fail in the closed position thus not allowing any water to enter the unit
You also may have a problem with your power switch but if it seems like everything is working ok but no water than i would deffinatly look at the solonoid valve being the problem
the cost to replace this is about 50 dollars if you do it your self and about 150 if a service man has to do it ok?
so i would contact a local appliance parts center that deals with your kind of machine and find out if they have the part on hand before starting any majior repair ok?
I hope that has been very helpfull for you
best regards michael
Popular Solutions for Washing Machines
Whirlpool Ultimate Care II LSQ9549L Top Load Washer
1 Solution
Questions and Unsolved Problems for Washing Machines
whirlpool ultimate care ii washer LSQ9110PW2
Westinghouse Washers and dryers
Gasket on washing is full of gunk from all the washing. How do I clean it out thoroughly - is there...
(More)
Gasket on washing is full of gunk from all the washing. How do I clean it out thoroughly - is there anything that will dissolve it so I can apply it in an empty machine and run it like you clean a dishwasher?
Power surge - machine receiving no power. Is there a reset button? Thank you!
My washing machine has stopped working due to overloading and gives out a burnt smell from inside.I...
(More)
My washing machine has stopped working due to overloading and gives out a burnt smell from inside.I doubt there is a circuit problem from the inside.Could help me with a customer service number to repair it?
