Question about Mintek LCD TV Progressive Scan DVD Player
Mintek dtv-265-d dvd broke
Bought this tv dvd stuck inside can't get it out
  • jimbo42 Feb 26, 2008
    The disc will open and close but the dvd does not work. Motor sounds like it is starting and stopping.
  • Anonymous Jan 05, 2009
    I am experiencing the exact same problem. It accepted the DVD then locked it in. It froze on the Menu screen and NOTHING ELSE works. I cant even bypass the remote and use it JUST as a TV unit.
To fix this problem, the following assumes you have unplugged and taken the back off the TV, and removed the metal shield around the mainboard. Open the back carefully as there are a couple of ground straps that must be unscrewed before the back is completely freed. There are plenty of lethal voltages inside the TV, so do this all at your own risk.
I'm an electrical engineer and I just fixed a DTV-265-D that I got with the same problem. I'm not 100% sure what fixed it, but I located the problem and can hopefully inspire some other findings by others. All TV/DVD buttons, and remote control signals go into a small miicrocontroller (U75) on the bottom left corner of the mainboard. This button converts all buttons and remote signals into a decoded data signal with a 5V level (normally high).
Just above and to the right of U75 is a small 8-pin chip that appears to split and send the data signal to the DVD module and the TV microcontroller at two different voltages. Pin 1 of this chip is on the bottom right of U18 and the pins increment counterclockwise. The important signals I found were:
-Pin2: 5V Data input from U75 microcontroller.
-Pin3: 5V data signal sent out the red wire of the connector next to U18 going to the DVD player.
-Pin5: 3.3V data signal sent to the main TV microcontroller.
-The other pins may switch this signal back and forth somehow, but I have no way of telling without a schematic
I found on my unit that something was causing the signal not to get properly to the TV or DVD player. I resoldered U18 and things started working again. I'm not 100% sure this is the final fix, but U18 IS THE ULTIMATE CAUSE OF THE PROBLEM. Neither buttons nor remote signals are ever getting to the DVD module or the TV. Once I resoldered, both signals on pin 3 and 5 were clean and everything worked again. U18 may need to be removed and replaced with a simple voltage divider to get the proper voltages to the proper modules, but I haven't tried to go there yet.
A way to test if this is your problem is to remove the red wire from the harness next to U18 (the harness going to the DVD player). Somehow connect this wire to pin 2 of U18 (there's a convenient test point nearby), reconnect power, buttons, etc. and CAREFULLY test. Now, ALL the buttons for DVD control will work again but not the buttons on the TV side will work. You should be able to eject the DVDs and this may have unlocked this weird state. You would have to restore the red wire back to it's original position to have proper normal operation.
I used (and would highly recommend using) an oscilloscope to fix and debug this. There are plenty of lethal voltages inside the TV, so do this at your own risk and only if you at least kind of know what you're doing with electronics. So far it's been a week and everything is still working fine.
Posted on Jul 27, 2009
Hi Milkman42,
I hope it is not too late but my friend had the same problem and I was able to fix it.
I posted my solution at
Posted on Feb 15, 2008
Well i just fixed my Mintek dtv-265-d none of my buttons worked either and it was stuck in dvd player mode so try this and if it works or you need more information email me. OK so i removed the whole dvd player and still had the same problem but then i started taking the dvd player apart and unpluged the dvd player from its bord that the tv plugs to and pluged that board back into the tv and all my bottons worked again dvd player sorce now says no signal but rest of tv works perfect
Posted on Jan 15, 2009
How to reset mintek dtv-265-d telivision after replacing power supply
MINTEK DTV-373-D OWNER'S MANUAL Pdf Download. > ... > TV DVD Combo > DTV-373-D
View and Download Mintek DTV-373-D owner's manual online. Mintek DTV-373-D OWNER'S MANUAL 37''. DTV-373-D TV DVD Combo pdf manual download.
Mintek DTV-265-D 26 in. LCD TV Factory reset - Questions ... > ... > Mintek > Mintek DTV-265-D 26 in. LCD TV
...factory reset to this TV. It will make all to factory settings. There are two types ofreset to TVs. The first is simple to do; a Hard Reset. The other is somewhat ...
Mintek reset button location Combination Televisions ... - Fixya
Dec 07, 2015 | Mintek DTV-263 26 in. LCD Television
Mintek tv/dvd combo dvd is stuck, volume is stuck, chanel is stuck
The model DTV-263/265 has this common problem, the main board will have to be replaced.
Oct 30, 2009 | Mintek DTV-263 26 in. LCD Television
How to remove tv base from mintek dtv 265 d
It fit in the carton with it on.  Thank you.
Apr 06, 2009 | Mintek DTV-265-D 26 in. LCD TV
Mintek -dtv-265-d stuck in DVD mode
These units have had a failure in either logic board or the main board. The only way to repair these units is to get replacement boards and see if this repairs the problem. You can try to source these parts at e-bay. Use the search engine, plug in the make of you television model number, and part number of the board you think you need for the repair.The search engine will bring up all available parts for you.You can also try this website for parts. I hope this information is of some help to you with your problem.
Mar 15, 2009 | Mintek DTV-265-D 26 in. LCD TV
Mintek dtv-265-d no pictue
I had purchased Mintek Mdtv 265D , after Reaching Home (India) Tried to switch on the syastem but Screen Doesnot get on, as Per local expert the pwer supply having some problm, The same Set purchased in Month Sep 07 from Somewhere in US
Now the same is in India , how to repair and get rid of this problm
Jun 05, 2008 | Mintek DTV-263 26 in. TV/DVD Combo
On-screen Menu
Actually, it is not a Projection TV Problem. The problem is with a Mintek DTV-265 26" flat screen digital TV (not projection). I have not yet resolved the problem by unplugging the set, pressing the eject button and replugging in the set nor have I had any other suggetions. The manual clearly indicates Mintek DTV-265 26" (not Mintek DTV-263) but I feel they are very similar; however, the manual does not mention losing/restoring the on screen menu.
Feb 28, 2008 | Mintek DTV-263 26 in. LCD Television
Mintek DTV-373-D Remote code
As far as I know, no regular universal remote will work with the mintek TV/DVD's.
I have heard that the "Kameleon" remote, from radioshack works with them.
I had the same problem, so I ordered a replacement original remote from ebay for $20. It was the RC-600 for mine (DTV-265 26" LCD/DVD)
Feb 11, 2008 | Mintek DTV-373-D 37 in. LCD HDTV
Lost remote for Mintek TV-DVD combo
contact manufactuer or electronics store about buying a OEM replacment remote.
GET THE factory contact info off of user manual
Dec 09, 2007 | Mintek DTV-373-D 37 in. LCD HDTV
Stuck DVD
I have a Mintek DTV-265-D which is frozen and neither the buttons on the set nor remote will work. Anyone know how it get it working?
Sep 02, 2007 | Mintek DTV-233 23 in. TV/DVD Combo
Mintek DTV-263 26 in. LCD Television... Problem:
I suggest you go to their website at: The DTV263 is not available online, but the DTV323 is there and this should be the 32" version of the same set. Download the manual for the 32" version.
Aug 20, 2007 | Mintek DTV-263 26 in. LCD Television
Mintek LCD TV Progressive Scan DVD Player Logo
1,096 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Jason Morris
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
