Bissell 37604 Lift-Off Pet Bagless Upright / Canister Vacuum CleanerVacuum
Problem for Bissell 37604 Lift-Off Pet Bagless Upright / Canister...
Not picking up cleaned all of filters is there a belt for this
By randlemedia on Nov 05, 2009
Solution #1
posted on Nov 05, 2009
Not Rated)
Vac Belts
Rank: Wiz  Vacuums  Expert
Rating: 80%, 63 votes
It might be because the belt is broken, stretched or worn. In all of these cases the vacuum won't pick up well. You can get the replacement belts for this model and download the manual which has instructions on how to change the belt here:
Bissell Lift-Off 37604 Replacement Belts and Manual
Was this helpful?
Yes
No
Popular Solutions for Bissell 37604 Lift-Off Pet
Questions and Unsolved Problems for Bissell 37604 Lift-Off Pet
Do you recommend Bissell 37604 Lift-Off Pet Bagless Upright / Canister Vacuum CleanerVacuum?
Answer
Answer
Bissel 3670-2 brush -roller dose not rotate at all even after I ttry to pull the belt. Could someone... (More)
Answer
The "clean filter indicator" changed from green to red. I changed both filters and cleaned... (More)
Answer
When I turn it on the filter indicator turns red but filters are clean and it will not pick up when... (More)
Answer
I have a canister bagless vacuum cleaner which is having the inlet at the front and the dust... (More)
Answer
Bagless Lift off Revolution Stopped running Do they have an overheating problem?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Bissell 37604 Lift-Off Pet...:
Top Vacuum Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Vacuum Experts
Top Vacuum Repair
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
