Question about Simplicity Serge Pro SW432 Mechanical Sewing Machine
Need replacement cutting blades on my simplicity serger easy lock 804
Where do I find replacemnet cutting blades? Can I order them online?
  • Anonymous Mar 31, 2014
    blade
Allbrand.com or go to Google, type in: "Replacement blades for a serger". Hope this will help. I have the same serger. --Tricie
Posted on Mar 29, 2008
Rabbit HX 720 Vinyl cutter plotter cutting blade will not lower to cut
Since this is a sewing machine category, it is unlikely there will be a good answer.
Aug 31, 2017 | Sewing Machines
Why did it suddenly stop cutting?
Please provide the model of your machine.
Ok, it's a serger. Wondered why a sewing machine would be cutting unless it had the cut-n-sew accessory.
Most likely the blades are damaged or malfunctioning. Is the blade still moving when it is stitching? Is it just chomping away at the fabric but not cutting? If so, either or both blades need to be replaced. Consult your owner's manual. Usually only one blade can be installed without any technical knowledge. You can probably order the replacement blade and install it yourself. However, the other usually needs to be replaced by a knowledgeable technician because it requires some precision.
Has the blade stopped moving at all? If so, how long has it been since a thorough cleaning and oiling? Take it for service.
Mar 25, 2016 | Elna Sewing Machines
I have juki ddl 8500 7 and the thread cutter will not worked
Is it making a noise when you try to cut? Most common is that your needle plate is bent down and is preventing your knives from doing their job. In this case, you can take the plate off, turn it over on a flat surface and use a hammer to flatten it. While the plate is off, test your machine and see if the blades are now moving. Make sure to keep your fingers away while you are doing this. :)
Now check to make sure your feed dogs are not cracked or broken and keeping the blades from moving. Next: Sometimes you either get a ball of thread or a piece of a broken needle caught in the blades as they try to cut and it can either bend the stationary knife (this knife is in the general shape of a backwards letter L) or break it off. If all the knife pieces are there, the small moving knife (that looks like a little flat fat bird with a big eye :) ) becomes dull and won't cut the thread when it moves against the stationary knife. In either case, you can replace the knife. The most common is to replace the stationary knife. It is the easiest to replace and can be ordered online with the part # from your parts book. If you don't have a parts book, try to contact your online sewing parts company for the part.
Mar 20, 2016 | Juki Sewing Machines
Machine does not trim
Consult your owner's manual. Make sure the upper blade has not been raised, ie for cleaning. If the blades have knicks or have been used for quite some time, it could be time for replacement. Usually, one blade can be replaced by the user, but the other should be installed by a knowledgeable technician. The owner's manual should have some instructions about changing blades.
Jan 02, 2016 | Sewing Machines
How do I find needles for my simplicity easylock 804 its four thread
I think you can find out thru any simplicity retailer.or by reading thru your owners manual.
Jan 02, 2015 | Simplicity Sewing Machines
My brother overlocker blades dont cut anymore and thet dont move either, please help!!!
if the blades don't cut then they need to be replaced,, and for the
blades not moving,, the machine need to be checked..
Apr 19, 2013 | Sewing Machines
My Bernette 203 will not cut the material or thread. I need to know the correct placement of the cutting knives.
First to see if the top blade is pressing against the lower blade when it goes past to make the cut.
You should be able to push the top blade to the right and have it spring back to the left. Do that to see if there is a small amount of presser on the lower blade.
Next, the cutting part of the top blade should drop just under the lower blade buy about 2 mil.
Also the lower blade should be level with the needle/stitch plate.
Blades also may need sharpened. The top one can be done with just about any sharpening tool but the botom is carbide so you will need a dimond wheel to sharpen it
Hope this helps
Apr 10, 2011 | Bernina Bernette 75
Simplicity Serge Pro SW432 Mechanical Sewing Machine Logo
561 people viewed this question
Top Simplicity Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
doylesouders
Level 1 Expert
Are you a Simplicity Sewing Machine Expert? Answer questions, earn points and help others
