Jenn-Air JCD2389G Side by Side Refrigerator
Ice maker doesn't work. changed filter. light on...
shared by 2 users
posted by kent low on Jan 05, 2008
Jenn-air JCDS2389GES
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Clarification Request
Posted by 2ironic on Mar 28, 2008
Lets back track a bit. How old is your unit? When you say that the water tastes worse than from the faucet, what do you mean? Does it have a plastic taste? Does it have a carbon or charcoal type taste, or is it more of a metallic type taste? You could possibly be getting a rubber type taste or a moldy type taste.  If you can narrow down how it tastes worse, you may be able to help isolate the problem. Next, what do you mean about the control panel being worn? Third, does the ice dispenser only jam when you have crushed ice, or does it jam when you dispense the uncrushed ice as well? I believe that the problem when it jams on crushed ice only is that the spring on the ice door has been engineered a bit too stiff for the crushed ice to push it open, causing an impaction.
1 Other User Has The Same Problem
Posted by Newtons on Feb 23, 2008
We changed the water filter, but the water tastes worse than from faucet. The control panel is worn and the ice dispenser jams.
Can you Help with these Refrigerators problems?
After Thanksgiving dinner we put all of our leftovers in...
Freezer is working but now cold air returning into the...
Jenn Air side by side.  The refridge temperature is...
Hi, I have a Kenmore refrigerator model number 10659582990...
i have voltage on the compressor but its not starting its...
Loading problems.
Repair Service
Find Refrigerator Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
