Question about Toshiba Satellite A60 Notebook
My toshiba laptop will not turn on...
About 2 weeks ago i burned a cd and then when it was done i took the cd out and left the computer running while i went to the ups store to mail something when i came back the computer was off and now it will not turn on. the lights (power button) turns on for two seconds when i push it but turns off right away. it wont charge meaning i plug it in and no lights come on. i have no idea what is wrong wit the computer if anyone can give me some suggestions on what to do that would be nice. Thanks
  • 9 more comments
  • Anonymous Jul 30, 2008
    Before I went on vacation I log off and turned off my laptop. When I returned from my 3 weeks vacation I tried to turn on my laptop but it does not turn on. I left it plugged in over night and still not turning on. The converter does not get warm so I tried a similar converter with the same output voltage and still not turning on. I also tried to removed the battery pack and held the power button for a minute and then put the battery back and still not turning on.
  • metalllinos Sep 09, 2008
    It turned off suddendly, and then wont turn on. lights turn on for two sec only when I press the on button. Thats all.
  • Hapytess Jan 09, 2009
    I had the same problem and I have been all over the internet looking for specifics to my Toshiba Laptop P105-S6147 including the Toshiba website. NO HELP. Finally I gave up and decided to look here one more time just using " Toshiba Laptop won't turn on". I was so tired and frustrated trying to find an answer, I almost tossed the laptop. I decided to try johnny6600's suggestion and YEAH IT WORKS!!!!!!!!! Thank you, Thank you, Thank you, Thank you! Absolutely wonderful! You should post this solution everywhere!
    I mean, if I had the money to take it to repair shop I wouldn't be searching the internet for an answer. I don't think I would have wasted so many hours trying to find a solution. THANK YOU SO MUCH,
    A much Happier Tessa!
  • Anonymous Feb 28, 2009
    my toshiba satelite laptop will not turn on. first i thought it was completely dead so i let it charge over night and tried it again. the blue light comes on when i press the button but nothing happens....
  • keely-b Mar 08, 2009
    My Toshiba Laptop will not charge even though the charger is connected and plugged in. I have tried several different outlets and have had no luck. Right now, the laptop is running on battery alone and should be completely out of power within the next two hours. Any suggestions on what might be the problem? Anything I can do to fix it?
  • Anonymous Mar 25, 2009
    Spot on worked the first time I did thank you can get on with my days work now and reorder a new battery for my laptop .
  • gotstaloveme Apr 10, 2009
    i have the exact same problem. i was on my laptop last night and i walked away to brush my teeth and wash my face, when i returned it was a black screen and wouldn't do anything. i had to hold the power button to turn it completely off then this morning i tried to turn it on and got nothing. it sounded like it was running and the power light was on but it wouldn't do anything.
    My suggestion;;
    johnny6600
    thank you SO much, that's the only useful information i have found, i appreciate it. thank you thank youuuu!!!!!!
  • Anonymous May 17, 2009
    20 Seconds worked for me too! Awesome!
  • yiiopamela May 25, 2009
    Almost the same thing but my laptop died so i pluged i the charger and turned it on i then logged on to aim it was goin find but then it just turned off
  • Ender
    Ender Sep 02, 2014
    You probably have never cleaned the dust accumulated inside your computer... and also you have not used laptop cooler under your computer... It is possible that you burned the chipset beacause your computer could not cool itself anymore.
  • qaisar_iqbal
    qaisar_iqbal Feb 28, 2018
    Unplug the Charger Remove the Battery ... Hold Power button for 1 minute ... i know its hard but its worth it ... try to turn it on only by plunging in by charger if its wont start .... move to next step ....(1st be sure that ur Laptop warranty is over... if not contact the store where u buy it).. open the RAM cover remove RAM's clean them with erasers ...now look carefully the Motherboard with RAMS removed ... u will notic on PCB there is a shap like button on the Circuit if u cant see it there must be a label Remove the label carefully not to damage it ..now put back only the Top RAM ... if u locate the Button like zig zag lines which are not coated with color are easily visible .. connect both lines with flat screw driver.. hold it for 10 Seconds... now Plug in Your Charger push the power on Button i hope ....... its start up and give u the display .. i did it once with toshiba.. just previous week and it was fine ..have a nice day
Here is the fix my toshiba laptop also wouldent turn on so i call them and here is what you do 1. unplug the laptop
2.take out the battery 3.hold down the power button for 20 seconds (doing this drains any excess power fron the unit) 4.put battery back in 5.plug in laptop 6.try to turn it on
hope this helps
John
Posted on Jun 07, 2008
  • 10 more comments
  • Hi2011 Jan 28, 2011
    Wow. This is excellent. Thank you very muchchhhhhhhhhhhh. It really helps.
    Hirut
  • gilbert4391 Feb 16, 2011
    Thank you johnny6600..it is really great....IT WORKS...EXCELLENT!
  • star_kid1 Feb 22, 2011
    thanks so much, it works like a charm, you are the man.
    many would charge for this type of knowledge, i wish you all the best
    from RAF
    UK
  • angelartiaga Apr 30, 2011
    Oh my goodness! This was brilliant! I was ready to loose it. Then I found u! The 20 second thing worked! I am so grateful. My laptop would power on but the screen stayed black and would go no further. The little circle thing near the mouse pad wouldn't even do anything. Now its all good!
  • **** Toshiba It hasnt blooming worked I have a funny feeling its the bios thats gone anyone got a solution!!!!????!!!! AnyONE?/???????
  • franciska31 Mar 01, 2012
    Thank you soo much for posting this I thought my laptop was gone.
    Thank you sooo much for posting this I thought my laptop was a goner :)
  • ahudock1
    ahudock1 Aug 12, 2012
    Thanks, this worked for me also. Nice trick to know
  • nurseauburn2
    nurseauburn2 Aug 31, 2012
    Holy cow! Thank-u SO much!
  • Michael Jennings Dec 01, 2012
    my toshida l500d-11r still not working
    I need help
  • beetlej69
    beetlej69 Dec 17, 2012
    THANX
TOSHIBA WILL POWERUP BUT WINDOWS WILL NOT START
Posted on Jan 28, 2010
My toshiba doesnt do anything not even a little light nothing its like dead literaly
Posted on Jun 20, 2010
Had the same problem with my Toshiba Satellite M45- S265. Solution turned up after pressing every key on the keyboard. The one that did it was the little button under the start button which had a world above it (looks like the Starwars Deathstar with arrows around it). It's with a set of black buttons that look like start, stop, rewind buttons on an old cassette deck.
Try pressing the Deathstar button and let me know what happens! What idiots would put a killer button under the startup button???
Brian mondomando @ yahoo . com
Posted on Feb 04, 2008
  • maoenieru Jul 10, 2011
    I have an L505 S5984 Best Buy model Toshiba as well as an older Toshiba which is still running. My newer laptop would not start and only showed the power light on the front which showed it was getting power. Removing the battery and switching power packs did not help. Pressing the power button with the battery removed for 30 seconds did not help.Next I unplugged and removed the battery. I removed the optical drive or dvd player which was easy because it is only held in with one screw. I replaced the battery and plugged in and Immediately it booted up and ran fine. I was prepared to remove the hard drive next and see if bios would work then but luckily i didn't have to because it was a short in the optical drive that kept it from powering up. Try removing these two components first and seeing if it will boot before blaming the motherboard or processor. Before doing this I thought I had a serious problem.
  • calgary_g541
    calgary_g541 Dec 26, 2012
    i have a toshiba satellite laptop and last week i shut it off like always and next morning it would not turn on so i kept trying the power buttin then after about 10 min of it comming on and going right back off it did tstart so i kept it on so last night i shut it off for the night and today had the same problem can any one help me with this
20 second solution didnt work for me =/
Posted on Jan 25, 2010
I bought my laptop in feb and now its dead no lights nothing could some one help me please
Posted on Oct 03, 2009
It's a shame that Toshiba laptops have this problem. I will never buy another Toshiba product. I spent $100 while under warranty days after I bought it, and it has never been a reliable computer. Back to Dell. I tell anyone who asks me about a computer to not buy a Toshiba. Bad service, bad computer, bad company to deal with.
Posted on Aug 07, 2010
Very helpful !!! It worked
Posted on Nov 29, 2008
My computer was uploading upgrades and then shuts down. After that not able to get it to fully load up. I press power button and it would power up but it the light would go right out and the screen never loads windows..Screen is black and looks like it is in hibernation. I have tried the 20 second, I have taken the battery out and used just the AC cord and even pressed power button to release energy still left in computer nothing is working. I use this laptop for my classes and I start a class tommorow:( I have only had this laptop for 4 months, how could this happen so fast and I lost my receipt:(Please any more suggestions on what I may try to get my laptop to fully load up?
Posted on May 24, 2010
My toshiba laptop wont come on the screen will just flash when i press the power botton, the battery light is orange so i think its charging HELP me please both it in August.
Posted on Dec 03, 2009
    Problem Solver:
  • 8 Answers
Take the battery out and turn it on, if it works, the electronics in the battery are bad, if it doesn't, the power converter is probably bad. maybe you can take the battery out and leave the ac adapter plugged in but the laptop turned OFF for a day or so. sometimes electronics build up a static charge and it causes the electronics to not work properly. good luck.
Posted on Jan 05, 2008
Wooooohoooooooooo! I did the 20sec. thing with the battery out and it totally worked! Thanks so much Johnny 6600!!
Posted on Mar 04, 2009
I was on it and the laptop shut cpmpletely off screen went black i tried taking the battery out , i unplugged it, the plug is fine i have juice coming from it, i blew the computer fans out with a house fan to get any dust or to see if the mother board was to hot that all still didnt help and i also checked to see if there was a fuse but didnt find one, pls can anyone help its not just a laptop to me my father passed in may and it was his it means more to me then being able to get on the net...pls help thx
Posted on Oct 15, 2009
The 20sec things works!!!!!!!!!!!!!!!!!!!1You rock Johnny6600, its 2010 and your solution still works....Thanks I was going to be heart broken
Posted on Jan 09, 2010
If you can access to mainboard repalce q545 voltage regulator.
Posted on Feb 02, 2010
  • Ardit Dashaj
    Ardit Dashaj Sep 29, 2010
    Q545 is a voltage regulator (2 IC in paralel), but does any one the part no or IC name of that? On my laptop they're damaged and i can't read IC name exept for the last 2 characters "YA"!
  • Mark Downing Jan 31, 2013
    Does anybody have a photo or diagram of where to find the Q545 voltage regulator IC's? Are they next to the batter connector?? It would be nice to know the exact location on the motherboard and I haven't been able to find a motherboard diagram on the internet.
I JUST did the 20 second thing and it WORKED!!! i am sooo grateful..ty i am in no position to pay for a repair and i would have had 2 bc i use it for work...thank you and god bless
Posted on Sep 26, 2009
    Problem Solver:
  • 6 Answers
My Toshiba m45 laptop wont turn on it runs for a minute then turns off. A
ll the light come on the fan comes on. The power cord will not run the laptop.
FIXED IT .. THIS MODEL WILL NOT RUN WITHOUT A GOOD BATTERY other laptops will run on the power cord but not this one. I got a new battery online and it works fine now . The geek squad didn't know this model must have a good battery for the cord to work
Posted on Sep 19, 2010
Johnny6600 you are the man. That is the perfect solution.
Posted on Dec 25, 2009
I did it and now the screen is blank with a blinking cursor in the top lefthand corner.
Posted on Nov 17, 2009
Laptop won't start, bummer. If the power light is on then you are getting power and your power brick is probably ok. Try removing the battery and just running off of the power brick. No luck? Try borrowing another power brick or go to the next step which is unplug, remove battery and press power button for 30 seconds. If this doesn't work the next step is to remove the optical drive and see if it boots. No luck? remove the hard drive and try to boot. If bios doesn't appear there is probably a problem with the motherboard or display or some component too difficult for you to repair easily. Take it to a technician. Good luck.
Posted on Jul 10, 2011
  • 24 Answers
I have a toshiba satillite and it turns off instantly after cutting it on...i did some of the solve this off this page and now it will come on and stay but it i move it will shut off again what can this be?
Posted on Jun 05, 2009
  • Paul Woodward Mar 04, 2015
    bad power connector, or other loose component. the power socket in laptop is nearly always the culprit due to in out of socket. sometimes the connectors can be moved to make a secure connection. if connector is loose u may not realise the battery isnt charging until its so low only mains is running it and then as soon as connection lost system crashes..
  • 3 Answers
Toshiba users using bios password:: ignore the blankness of the screen and enter your bios password and hit the enter button. worked for me..hope it works for you too. **goodluck
tvo
Posted on Aug 06, 2010
This is for anybody else out there who might have this problem in the future......
I tried all the above, no joy!
I had the luxury of another M70 spare so I decided to swap out the Power circuit board, and it now works. However I tested the 'faulty' board back in the spare M70 and it is still functioning.
So my conclusion is that simpoly unpluging the power circuit board from behind the keyboard would have sorted it.
Posted on Apr 08, 2011
I had this same problem with my laptop and none of the fixes above worked. So i decided to start looking inside. I opened it up and right under the keyboard is a fan and it was real dusty. I took a brush and cleaned it and it powered right up. Hope this works for someone else.
Posted on Jul 16, 2010
  • cindy queen Jan 10, 2011
    I think you are right !
  • Michael Bystrytsky Feb 24, 2011
    The 20 second power off trick worked for me, thanks for the advice.
    New Friend:
It worked, and just try this:
hope this helps
John
Posted on Oct 12, 2014
    New Friend:
I tried all solutions but opening up the back of the machine. Nothing worked. I took some 3M Dust Remover and sprayed the ultra-cold gas in the openings, waited a few minutes, and then turned it on. It powered up right away. Not sure if it was due to the "static charge" someone had spoken about earlier. I just had a mother board replaced one month ago for the same issue, so I knew it probably wasn't that.
Posted on Jan 10, 2013
  • mbesandrus
    mbesandrus Jan 10, 2013
2 Suggested Answers
  • 7 Answers
SOURCE: my toshiba laptop will not turn on...
Sounds like there is a lot of static electricity in your home and you are frying computers. Try spraying fabric softener on the carpets before getting a the computer fixed.
Posted on May 26, 2009
About an hour ago, done a Toshiba Tempro BIOS upda...
Oh dear that's the worst thing that can happen during a bios update. the bios chip is probably now useless rendering the laptop useless. You will need a new motherboard I am afraid to say.
Jul 25, 2017 | Toshiba Satellite Pro L300D-EZ1002X...
This could be a few things. It could be a bad power cord not charging the battery or the machine. But it could also be various other things. The cheapest and easiest thing to try is a new power adapter.
May 26, 2009 | Toshiba Satellite A60 Notebook
Why Won't My Toshiba Satellite Laptop (A200 -AH3) Not Burn Discs?
Look for any software on the machine that uses the the burner. Start by updating it (many of these programs use what are called burning engines to process the request to write to a cd, and if theyre damaged, then the writing process will appear to occur, but wont do anything). If you use programs that download and manage music (such as Limewire, Bearshare, or Napster), uninstall them.
As a last ditch effort, you can try the istructions in this Microsoft article:
http://support.microsoft.com/kb/314060
Be warned, you will have to reinstall the software needed to burn your CDs if you do this. It has fixed 99% of CD burning issues out there. Good luck
Mar 05, 2009 | Toshiba Satellite A135-S2386 Notebook
Power down
I know the original post is over 2 years old but I had the same problem. Here's what happened:
8 months after buying my Toshiba A135 the battery began charging only intermittently. It also would not run without the battery. I put up with it for a month then took it back to Best Buy to get it repaired under warranty. They kept it over 2 weeks then gave it back saying it was the battery, which they replaced. One week later I had the same problem again. Back to Best Buy. The guy at the counter said it was probably the battery, they had encountered a lot of that. I said no, explained it, and gave it over to be fixed. 2 weeks later I got it back. They had reset the BIOS, no hardware replacement. I got it home and it was not fixed. I took it back the next day. They kept it 2 more weeks. They replaced the motherboard. I took it home and...you guessed it the same problem on the day I got it home!!! I took it back with one week left on my warranty. I don't remember what they replaced the last time but I think it was the motherboard again. I got it home (2 weeks later) and THE SAME PROBLEM on the day I got it home. So, the lesson there is that Best Buy computer maintenance SUCKS!!
I called Toshiba to try to get them to fix it for free, and out of warranty. After several frustrating minutes of conversation with an accented person who just kept telling me that my warranty was up, I hung up and called back and got an English speaking person. SHE was very helpful, listened to my problem, agreed to give me a one-time fix ticket. They paid for the postage. When I got my computer back it was mostly fixed.
The problem was the module at the back of the computer where the power cord plugs in. It was defective. They replaced it and it worked fine after that, except that when it goes into sleep mode it will not wake up. I fixed that by turning off all the sleep mode options. BTW, a friend of mine with the same computer is now having the same problem.
May 06, 2008 | Computers & Internet
Portege 3500
Hi
You can obtain the Recovery disk from Toshiba. Toshiba hotline number 1-800-457-7777 (US) 0844 800 6020 (UK). You need to provide your computer's part number correct to get the matching recovery disk. Usually they charges $39.95 including shipping to your address in US. Alternately you can go to http://uk.computers.toshiba-europe.com/cgi-bin/ToshibaCSG/generic_content.jsp?service=UK&ID=Support_Homepage_uk
Good Luck
Dec 29, 2007 | Toshiba Portege 3500 Tablet PC
Toshiba Laptop Keyboard Malfunction
If you boot a XP cd and select repair will it let you type?
Sep 21, 2007 | Toshiba Satellite A85-S107 Notebook
Toshiba Satellite A60 Notebook Logo
58,728 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
