Whirlpool GEW9250 Electric Dryer
Problem for Whirlpool GEW9250 Electric Dryer
Dryer is turning, no heat is coming out, timer is
By lucas_sheffi on Nov 05, 2009
dryer is turning, no heat is coming out, timer is not working
Solution #1
posted on Nov 06, 2009
Not Rated)
rogrrabbit
Rank: Guru  Washers & Dryers  Expert
Rating: 90%, 226 votes
The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house. If everything is good and you have paid the electric bill, then the timer could be bad.
Was this helpful?
Yes
No
Popular Solutions for Whirlpool GEW9250 Electric
Questions and Unsolved Problems for Whirlpool GEW9250 Electric
Do you recommend Whirlpool GEW9250 Electric Dryer?
Answer
Answer
sensing button stays on and dryer does not start
Answer
the dryer control panel is not working. Sometimes it wont turn on at all. When it does, the dryer... (More)
Answer
the dryer stopped heating. any ideas? mark
Answer
How to fix dryer element Clothes do not dry on first cycle.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Whirlpool GEW9250 Electric...:
Top Dryer Experts
Rank: Guru Guru
Solutions: 14911
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Dryer Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
