Question about AOpen AK77-8X Max (91.8A710.101) Motherboard
Ak77 8x max
When i turn the PC on, nothing happens at all. led1 seems to be on all the time, i'm running a sempron 2800, and a Sata 120 gig hard drive, any idea what might be happening?
  • blacksilence Jan 05, 2008
    I'm wondering if i'm having a memory problem, because the bios doesn't even show, the screen is blank and it stays blank from the moment i turn the machine on. I';ve resest the bios, and LED1 is still on, i'm not sure what that means at all.
  • 3 Answers
A bootable will work out
Posted on Jan 05, 2008
Generally speaking, you can replace any SATA hard drive with any other SATA hard drive. Notebook SATA drives are all the same size, basically, (2.5 inch), and desktop drives are generally the same size (3.5 inch), Desktop and notebook SATA drives will connect to the same power and interface cables, though desktop drives require more power. Just make sure that you pick a 2.5" drive for your notebook, or 3.5" drive for your desktop, and the drive will attach with no problems.
As for the size of the drive, to my knowledge, any system with SATA should support any size SATA drive (I put a 500 gig drive in my notebook, where the stock drive was 160 gig).
Feb 28, 2010 | Dell Inspiron 6400 Notebook
I have a asus AV7 with a amd 64 bit processor 2 gigs of ram windows Xp Pro 7 dvd burners NEC 16x and 2 120 gig 133HZ.sata drives and 4 133 ATA hard drives 133 maxtor 120 gig configured in a raid stripped 0...
There is a glitch on those AV7 boards ata controler I think. Check the website for the new drivers supposedly they help, but all they did was crash my raid after I installed them. I ended up cloning the whole raid over to a single large sata drive and put in an ide to sata card (non raid unfortunately) and the problem went away. I only had the problem under very heavy disk loading. It seemed to not be quite so bad when I added some additional cooling aimed at the motherboard. As to if it will help your software problem I am unsure. However the only time mine did the mini dump was when I was doing heavy video editing work and after nixing the raid it fixed it, But then again a bad drive in a raid can cause that also.
Sep 10, 2009 | ASUS Computers & Internet
After installing hard drive, monitor, keyboard, mouse not working
Have you tried to enter BIOS? Are you able to enter BIOS?? There may be an option you have to hit to enable SATA, and to select the boot device order, which may be messing things up.
Also, remember that STATIC ELECTRICITY is your enemy! Ground yourself when working inside the case.
Dec 30, 2008 | E-Machines eMachines Desktop PC
Sata hard drive
Check to see if your motherboard has a sata controller on it. The user manual will tell you. You can get a new on on If it does support it, you will need sata drivers for it which you can download from the website as well.
If it doesn't work you can add one external by picking up and external drive case for sata controllers. Then all you need is a spare USB 2.0 port. Make sure you get one with a power supply for it because at that size getting 500 gig to work will require extra power to perform properly.
Aug 05, 2008 | ASUS P5LD2-VM Motherboard
Acer Aspire 5100-3583
What size drive is in it now? The user manual should tell you what size drive it can use. If you are not sure, the best thing to do is to go back with the same size. The brand does not matter. Is your hard drive IDE or SATA? What is the model of your laptop?
May 30, 2008 | Acer Aspire 5100 Notebook
Amd sempron 2800+
i want AMD Sempron(tm) processor 2800+ free downloads driver
May 27, 2008 | AMD Sempron 2800, 2.0 GHz 2800+...
Install hard-drive
Sata drives don't have an option to be master/slave like IDE drives, b/c the Sata cable is per device. If the computer's not pulling up the sata drive, open device manager (right click  my computer, properties, hardware tab, device manager) and look for a yellow question mark. You'll have to install drivers for it more than likely.
May 16, 2008 | HP Compaq Presario SR1300NX (PP195AA) PC...
Sempron 2800 cpu speed
hey, here is the latest bios witch is required for your new sempron!
Dont foget to rate the solution as fixya! Thanks
If you need more assistance let me know, I'm here to help
Apr 02, 2008 | AOpen vKM400Am-S Motherboard
AOpen AK77-8X Max (91.8A710.101) Motherboard Logo
137 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
